I don't endorse opening your amplifier:
Disclaimer, you are choosing of your own free will to willfully open and void your warranty, any and all damage is your sole responsibility and I am not responsible for any damage that may occur as a result. If you agree to this, I will send you detailed instructions via personal message.
Shoot me a personal message and I will respond to your question, mine has been open 3 times in total. Don't attempt it without having a basic understanding of engineering/assembly. The BT antenna cable length seems to vary by production run.
I have a family member that had a stroke and I'm the medical proxy, or decision maker from japan to fairfax virginia usa. I'm not able to respond to messages immediately but I am checking and reading the board once a day or every-other day at this time. I will reply to your personal message or whatever the forum calls it. I just don't want to tell everybody how to disassemble the amplifier and anger SMSL!
i couldn't resist my curiosity and opened it...
what i see first was as your amp. thermal grease is almost non existent at all, barely touching cooling meatal of the chips, see below,
i think %20 of the cooling area is dissipating heat to lower plate. I removed the grease and fully covered it with better one.
in addition to it, i added 1 nichicon fine gold cap 35V2200uf to output caps on the psu. All three caps on the psu is in serial connection,35V 560ufX2 + 1x 35v390uf Rubycon ZLH series.I just added 1 Nichicon. This really helped at high listening volumes, lower frequencies are more prominent now with better defined treble/less harsh. I will also add a 400V 100uf matsushita cap to reservoir section, cap. i see in this psu is garbage.
I've a much better 24V PSU for this amp, i highly recommend bypassing current psu with better one if you listen at high volumes. This amp simply uses 24V dc, you can easily solder psu output cables to jack behind of the amp and from then you can use your external psu.
update: added 400V 180uf Rubycon BXW cap to reservoir...Bass is definitely improved, audibly punchier bass after that cap. If you'll use stock psu, i highly recommend to add similar caps to your psu.
psu of the amp, shame there's no any photo is smsl page similar to this ones...lol
i'll bypass current psu with this one soon, i also modified with much better caps.
