If you are using what’s in effect a filter what’s the point of using a full range speaker instead of a 2-way and use a crossover that use similar number of components?That's why you use eq, be it passive or active (analog or dsp).
Nice house, man!Single point source that is time and phase aligned where the cone of the woofer is not the variable waveguide of the tweeter and so disturb the sound. (the problem with coaxial cone drivers). And no, this is no monitor style neutral speaker, it was not ment for that (not by me and not by Fane). It's something that works well outside or in big spaces. It goes loud on little what, and does that with decent bass, till subfrequencies on low power (<20w) what is not a problem with measured 98dB sensivity (advertised 101dB), even for in my garden (the purpose of my build). This is where they mostly are used (but stored inside), in my garden.
Nope! A single driver used wide-band shows, necessarily, huge aberrations in what you call 'time domain'. Please, in case show some data, thank you!... degraded time-domain response of the two-way speaker. David Griesinger talks about ...
Could someone even use what Omega Audio is selling with a modern AVR that's pumping out !140W/channel? I understand at normal runtime, it is much lower, but what about during room calibration? One would not want to damage the speaker on the first use.Some years ago a customer called me with an unusual situation.
He has a special-needs son who likes to watch children's shows like Sesame Street, and he wanted to make that as enjoyable for his son as possible. So he tried using some nice two-way bookshelf speakers to improve the sound quality over the little TV speaker. The sound quality was much better to the father but was worse for the son, who could no longer clearly understand the words.
I figured the son was having trouble processing the voices because of the degraded time-domain response of the two-way speaker. David Griesinger talks about the perceptual benefit of having the overtones all arrive at the exact same instant as the fundamentals for maximum vocal clarity, and this is an area where the "one-way" speaker in the TV had better behavior than the two-way bookshelf speakers.
So I directed the customer to Louis Chochos of Omega Audio, who set him up with [wizzerless] single-driver ("fullrange") speakers, and the customer and his son are both very happy with the results.
So imo there is a place for what a good single-driver speaker does well, even if there are some inevitable compromises involved.
I don't have a library of relevant data on fullrange drivers, sorry.Please, in case show some data, thank you!
Thanks, it's a ancient fortified Picardian "square farm" (ferme carrée) in the Hainaut region in Belgium, going back over 1000 years but rebuild several times in history. I only live in a part of it as it's huge. It's now converted/divided in 8 houses, all of decent size (arrround 150m² living space, wich is above average in Belgium) and updated to the 21st century on comfort and amenities.Nice house, man!
... and that's the point with urban legends ...I don't have a library of relevant data on fullrange drivers, sorry.
Each multiway and single driver have their good and their bad side, and should be used in the right application. I get why "ASR people" are not fan of those in general, but i still love them even lf they are not neutral.A wizzerless wideband driver has no more time domain aberrations than any other cone which is driven into well-controlled breakup. I should have specified that this was a wizzerless driver, and have edited my post accordingly.
Crossovers introduce a phase differential between the highpass and lowpass drivers, which often sums to one wavelength (360 degrees) in the crossover region. This places the lowpass driver "in phase with" the highpass driver in the phase domain, but delayed by one full cycle relative to the highpass driver in the time domain. A single-driver speaker does not have this type of issue.
Here is researcher David Griesinger on the importance of the harmonics lining up with the fundamentals for the sake of clarity and intelligibility (he uses the term "proximity"); the context is concert hall psychacoustics, but imo the underlying principle is relevant to home audio. To illustrate his point about speech intelligibility he uses a small single-driver speaker which has a linear phase response from about 100 Hz to 8 kHz. From where it's cued up he gets his point across in a little less than two minutes:
Imo the whole lecture is excellent, but most of it is outside the scope of this thread.
I don't know; you'd have to ask them. My instinct is that 140 watts is probably way too much power for a single-driver speaker, but on the other hand their efficiency tends to be fairly high so less power is needed for a given SPL. Use "small speaker" mode to protect them from bass excursions, which are not only potentially damaging but also introduce intermodulation distortion which degrades clarity at high SPLs.
That being said, I would not recommend single-driver speakers for an application that was demanding in terms of SPL.
I suppose the traditional response would be for me to counter with a demand that you present data to prove your position.... and that's the point with urban legends ...
We'd have to have measurements of both speakers to settle the debate so agree this is a dead end. I would say the story sounds possible to me because we don't know how badly the crossover might have mangled the response of the 2-way. It's also worth emphasizing that the listener in this story was (I take it) not neurotypical and so could have had a different sensitivity to timing than other people. That was sort of the point. Enough variables that we can accept this as entirely possible IMO.I suppose the traditional response would be for me to counter with a demand that you present data to prove your position.
And thus would begin yet another internet forum death spiral, each of us asserting that the other has the burden of proof and/or dismissing whatever the other person says. We'd start with insinuations and if those fail to win the day, we'd escalate to accusations.
Thanks for the invitation, but no thanks.
That being said, I am interested in your opinion on the time-domain behavior of single-driver speakers versus multi-way speakers. No proof demanded. Maybe you know something I don't know, in which case I would rather learn from you than squabble with you.
It's also worth emphasizing that the listener in this story was (I take it) not neurotypical...
Nice to learn new terms, which politely set someone apart. As far as it is about the merits of wide-band versus multi-way speakers, many things might be scrutinized. As far as I'm concerned the 'phase' thing is described as -> group delay. Sure, an x-over will typicall introduce some, but for two-ways especially there's proven no problem with less than 1ms of g/d. The x-over as such just works fine.My recollection is that the man's son was either non-verbal (he did not speak) or he spoke very little, but he clearly enjoyed watching children's television shows, and his ability to clearly hear the dialogue in particular made a big difference in his enjoyment. So yes, he was "not neurotypical".
All this talk about no phase shift and point source being somehow more "natural" is kind of pointless...
Do you acknowledge how much the signal to the, as you put it, hopefully not speaking of me, ear/brain system is altered in his example? This won't ever be a remote case for speaker replay. It is beyond orders of magnitude, it is something entirely different.According to psychoacoustician David Griesinger, if you mess up the phase of the harmonics, speech becomes difficult to understand ...
I've also read where an audio person's significant other, English wasn't their first language.
Using a full range driver was easier for her to understand what was being said watching shows and movies.
Anecdote (I love it to pull in subjective experience): 've got large, pro/ DML speakers. These are characterized by utterly random phase in the acoustical output. More so, the designer of such a thing longs for the most chaotic phase he possibly could get, as the better the underlying principle it brought to work. Result: brilliant speech intelligibility due to effectivly avoiding descrete in-room reflections, because phase is not only frequency, but also direction dependent. No such effect that Griesinger refers to. Must be something different, right?
Back on topic, one should understand that Griesinger's explanation targets a scientific experiment asking for the very foundational mechanisms of human hearing. It is in no way, not even remotely connected to audio.
The original signal was transformed into another dimension. One may question if such alterations are at least related to the hearing! Hence no disclosure of any hypothetical mechanism that makes the change for the receiving device under test, the human namely. Science? Model, hypothesis, measurement. None of that here, I actually don't like to say that.Griesinger shows that phase degradation results in intelligibility degradation. Exactly where the audibility threshold is, I don't know.
Sidenote only, DML have as chaotic phase response as humanly possible with a speaker. Doesn't degrade audio quality. A pratical case against your claim.I have no experience with DML systems, but "avoiding discrete in-room reflections" sounds like a very desirable attribute to me.
Human hearing is. Griesinger, whom you quote as to support your claims and musings, is talking about a scientific experiment, that remotely has to do with phase--maybe! It is only so that the common audiophile isn't educated in neuroscience, physiology, mathematics, so called psychoacoustics and stuff. From my perspective even it is sometimes hard to understand what some experiments and describing papers are after. Often the statistics is flawed, but more often the investigations are at best after elementary , let's say, correlations within the hearing to generate more, yet unsolved problems in understanding even the basic mechanisms. Do you think that investigating the primary visual cortex's internal signal processing helps with improving the quality of printed fotos of sculptures? Long way, isn't it?I happen to think human hearing is very much connected to audio.
Agreed, and I suggested to the board to investigate personal thresholds for e/g intermodulation distortion. Interest was nil, zero, nada. Utter silence, ignored. And then again some papers on psychoacoustics are thrown in as to support some wacky audio gosip, and the fellow didn't read it himself--no time to do so, but the title seemed to fit ...And imo this characteristic of human hearing has implications for audio, as it indicates that there are thresholds best not crossed.
