Sigberg Audio @ Purité Audio London
Purité Audio
Industry Insider
Barrowmaster
London
The entire Sigberg Audio will be available for audition at Purité Audio London soon!
Including the sensational dual cardioid four way ‘Manta’.
https://www.sigbergaudio.no/
Digby
I like the look of the narrow subwoofer, more of this please manufacturers. Sadly a little out of my price bracket, especially if, ideally, I need 3 of them.
Digby
For evening out the bass response throughout the room thing.
Digby
No, just a normal listening room. You think 3 is unnecessary?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Which speakers are you using, I would start with one, listen, measure …
sigbergaudio
Norway
If you are lucky, even one will work well in your main listening position with a bit of eq. If you require even bass over a wider area, or are limited in placement options, you may need two.
So I agree with Keith that starting with one is a good idea, unless you've already experienced that a single sub doesn't work in your room.
radix
You should use both measurements and listening to guide how many you need. If you're lucky, 1 might be OK over your desired listening area. It is specific to your room reflections and listener positions and sub placement and how close to a response curve you want to get. Anyway, I'd start with 1 and measure and listen then add more as. you find the nulls/dips. Repositioning can make a big difference too, and you might be able to move a null (where reflections cancel) out of the listening area.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I really am looking forward to receiving these:-
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
They look purposeful and just slightly threatening.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
These are the Manta’s dimensions,
  • The speakers are 36x60x35cm / 14x23.5x13.8 inches
  • Weight per speaker: 24kg / 53lbs. Estimated total shipping weight with included stands (custom, one piece black steel stands): 60kg / 132lbs.
  • Total height on the stands will be 107cm / 42 inches - with the tweeter at 96cm / 37,8 inches.
The MEG 901s
500x500x430mm
sigbergaudio
Norway
Maximum sound pressure tests has been conducted with CTA-2034 pink noise today. :)
Specs updated as follows:
Maximum SPL of 122dB@1m (per speaker)
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
More than enough to annoy the neighbours.
sigbergaudio
Norway
@sigbergaudio Very cool! Available for audition in US yet?
Thank you! I'm afraid not, and currently there are no US dealers/retailers either. We are mainly an internet direct company. We have Wyatt Audio outside of New York, but currently that collaboration is mainly around our subwoofers customized for Quad ESL63.
Where in the US are you located, and are there any dealers / retailers near you that you think would be interested in retailing this?
