Shouldn’t we be looking more at PA speakers?
RobL
I'm afraid I can't agree with your impressions of the EV. I found the (rough) treble had a weird phasey quality as you move around. A quick glance at the published frequency response shows what I'm talking about. It ain't pretty.
Chris
Were you listening to a single or a pair? I’ve heard that column speakers playing stereo can be pretty phasey.
napfkuchen
Germany
A friend of mine uses a pair of Bose L1 Pro together with two different sized Bose subwoofers. Bose gets some hate from audiophiles but they certainly know how to Design PA products and nc headphones. The last time I heard this system (only with one subwoofer) was at a venue with about 300 people. The effortless output and even sound distribution were exceptional. After the Event I asked him to really crank it up for a short time... Amazing for such a small system. My Genelec subwoofer is similar in size with laughable SPL capability in comparison.
For me this changed brand perception for the better.
Duke
Princeton, Texas
At a friend's attic, F215+ :
https://www-audionet-com-tw.transla..._sl=ru&_x_tr_tl=fr&_x_tr_hl=ru&_x_tr_pto=wapp, JBL C222 :):
I'm curious about the short stands in the upper image; seems to me the center of the compression driver would have been right about at seated ear height without them. Do you know what the thinking was behind using the stands? Maybe they're 2.5 ways, and he's putting the midpoint between compression driver and horn at seated ear height?
On the other hand, the MHM format speakers in the lower image look to me like they would benefit from short stands to get the center of the compression driver closer to seated ear level. Looks like that's from an audio show of some kind, so unless they told you their reasoning I wouldn't expect you to know.
Both of those speakers LOOK well thought-out to me, otherwise I probably wouldn't have noticed the counter-intuitive (to me at least) compression driver heights.
RayDunzl
Central Scrutinizer
Riverview FL
gnarly
One thing about horns, ones that are used from midrange up...... say anything above 600Hz......is that I've yet to measure one of any kind, that was at its finest directly on zero degree axis...horizontal or vertical. Mouth termination issues get magnified when measured at strict perpendicular and centered, on-axis, ime.
About 10 degrees off-axis. is generally the best angle I've found to use as the tuning reference axis, to obtain best overall best set of polars. (and a nice listening reference axis.)
Applies to vertical too, especially for more axisymmetric horns.
So, I guess what I'm saying, is I'd take that into consideration if tuning to a seated position.
Duke
Princeton, Texas
One thing about horns, ones that are used from midrange up...... say anything above 600Hz......is that I've yet to measure one of any kind, that was at its finest directly on zero degree axis...horizontal or vertical. Mouth termination issue get magnified when measured at strict perpendicular and centered, on-axis, ime.
Thanks!
I've been designing for off-axis-in-the-horizontal listening (typically fifteen degrees off), but hadn't carried that over to the vertical.
Flaesh
Eburg
I don't remember.
Yes, "Below 250Hz both LF drivers shall operate together to produce low frequencies whilst above 250Hz only the upper driver shall operate to reproduce the midrange up to the crossover point." https://martin-audio.com/downloads/archive/datasheets/f215+datasheet.pdf
Sounds good enough\somewhat similar to my home system; I would prefer a larger horn and a lower crossover, but my friend doesn't want to change speakers.
The photo (taken from open sources) is old, two 21" subwoofers in IB in front wall have been added since then.
I haven't heard C 222, all responsibility lies with the exhibitors)))
Theta
This is actually an issue: PA speakers are for big rooms (like a warehouse), while HiFi are for small rooms (like US midwest living rooms). PA speaker construction does not consider the room acoustics of small rooms.
Even a cheap 12-inch or 15-inch woofer probably distorts way less at home audio levels than an expensive 6.5-inch woofer.
Cheap 12 inch or 15 inch woofer actually sound better than 2 or 3 6.5 inch expensive woofer and calculating the total surface area of multiple small woofers is totally misleading.
norman bates
Iowa, US
lol, I had a single speaker setup like above, post #65
double eminence magnum 15lf crossed 24db LR @ 750hz to jbl 2435 beryllium diaphragm on a jbl 2384 horn (much horn eq needed).
Very fun system, not the most delicate, but very very good.......
gnarly
Sweet. I've oscillated between 10 and 15 degrees horizontal many times, ...maybe I just need to lock down on 12.5 degrees haha.
I found vertical has the same on-ax issue, when I built an outdoor mast with mics vertically spaced.
Flaesh
Eburg
Regarding ready-made PA\cinema subwoofers - they may be used in a room with good results like the one shown above. Ports can be blocked. Choose bigger boxes and better drivers. Room gain or plain wave radiation will help.
you value SPL over finesse.
We need finesse defition! (in relation to sound reproduction). Quite sufficient SPL capabilities can be considered a bonus when using a large format driver, 15" midbass and proportionate subwoofers.
norman bates
Iowa, US
Is it 2.5 way?.. 750Hz seems too high for a bottom driver
Nope, was just fine at 10' away, and room filling also.
But yes, highs did pull to the horn.
Impactful bass even at medium volume, no subwoofer required.
I often yearn for more punch (midbass) with what I have now (hard to leave that setup), but my mids/highs are better now (12" crossing to nicer jbl pt waveguide at 1.2khz).
Flaesh
Eburg
Driver integration might be a problem if your MLP isn't far.
I very appreciate the driver integration; low crossed 2ways usually pretty good in this regard.
Line arrays of small drivers are interesting also, but I haven't had a chance to listen to such speakers.
they definitely clash with most home decor.
domesticated :D2360A (I couldn't find a pic of painted gold, that decorate someone's interior))
images
As to why Amir or Erin don't test them?
Amir tested https://www.audiosciencereview.com/...s/jbl-srx835p-reviewed-powered-monitor.25300/
PA speakers (drivers) for
All Unison Research Maxes made of PA drivers and waveguides for example
Wouldn't 2.5 add some delicacy?..
norman bates
Iowa, US
meh, sounded fine.
"You have not lived until you experience a speaker with such high dynamics."
from the referenced above jbl review.
