At high prices.
bought a car lately ?
At high prices.
All the Rega decks have easily removable arms, though the arm may be the best bit.The missing piece is a moderate priced TT with either no arm or an easily replaceable arm. Almost everything I've seen where I can drop in the arm of my choice is stunningly expensive.
I have a couple of great tonearms, so my interest is something with a basic drive system and a good suspension, where the engineering went to that, not to an arm I don’t need. And at moderate pricing, no voodoo.All the Rega decks have easily removable arms, though the arm may be the best bit.
Isn't that the problem?
Amir has pointed out that some Schiit products don't perform well.
He has identified serious safety issues in some products on account of ineffective casework earthing.
Members have identified issues with this turntable at the same time as others have said they like it.
Some Schiit products have been measured by Amir and commended as good products by Amir.
Topping products have often displayed exemplary measured performance at low prices.
All of that is objective and pretty much evidence based but is presented by some as an anti-Schiit crusade.
Certainly if I compare Amir's pretty balanced and objective approach to testing with the "shoot the messenger" approach of Schiit when certain issues are highlighted it would not be Amir who I'd criticise.
So you want a TT that costs a arm but not a leg?The missing piece is a moderate priced TT with either no arm or an easily replaceable arm. Almost everything I've seen where I can drop in the arm of my choice is stunningly expensive.
That's always been my position. Turntables should all sound the same when playing a record, they just have to go round at the right speed with minimal rumble. I accept that most turntables are used in the same room as the audio is playing, so are subject to feedback, so differences in turntable sound may be due solely to the way in which feedback is more or less isolated from the sound field the turntable sits in."Good" is an extremely loose (and nearly meaningless) term. Especially given the number of people who love a good story more than they can hear defects like rumble, wow, flutter, and the like.
A turntable's job is simple- rotate the record at a constant speed while not adding noise. If it does that and it doesn't sound "good," the problem is elsewhere.
Whenever folks agree, that does not necessarily mean it's some sort of coercive psychological phenomenon. Don't over think this as some manifestation of Gustave Le Bon's insights into social psychology. It might simply be that folks honestly agree about something. In this case, the turntable, it just doesn't look like good value, compared to other products available at the price point. That is a value judgement, not 'groupthink'.Every time I read the bullshit bias against Schiit here, it strikes me as group-think.
From my investigations, arm/cartridge resonance (which is probably not what you are talking about--i.e., overall FR variations, if I understand what you mean) manifests in an inability to properly track the groove, especially with record warps, at low frequencies, between 5 and 10 Hz. You can observe arm cartridge oscillation with test records. Sometimes it is audible, sometimes not.Arms are all different, but I've not seen any evidence (as opposed to anecdote) that an arm's resonant behaviour actually translates to audible differences in terms of frequency response. Cartridges yes, they're transducers, and as such differ considerably in terms of frequency response and distortion.
I’m not criticizing Amir, it’s all of the sheeple.
Hi guys! First post.
I get it about the round cross-section of the belt, and whatever else that might mean, but IMO that's all moot if the thing sounds good.
And so far, I don't know that anyone has heard it.
Something one may want to read before buying the SOL at this moment.
One can say a lot of things about Marv but he does know something about vinyl.
Tracking ability is a function of recorded amplitude which in turn is a function of frequency distribution and velocity, due to the RIAA characteristic. At LF it will be made worse if the arm/cartridge resonance is wrong, i.e between 9-15Hz, ideally 10-11Hz, and/or badly damped. A 'wrong' resonance but well damped is better than the 'right' resonance undamped. That's why I rate highly the Shure V15-V method of a damper on the cartridge which keeps the arm/record height pretty constant compared with arm damping which mostly doesn't work, whether at the cartridge end, as Townsend does, or at the pivot end, as SME do.From my investigations, arm/cartridge resonance (which is probably not what you are talking about--i.e., overall FR variations, if I understand what you mean) manifests in an inability to properly track the groove, especially with record warps, at low frequencies, between 5 and 10 Hz. You can observe arm cartridge oscillation with test records. Sometimes it is audible, sometimes not.
FR can be a major determinant in identifying a cartridges 'sound', if the response variation is large enough. As an example, see David Rich's measurements of the 'hot' AT 440ML. On the other hand, FR cannot be the sufficient determinant of phono cartridge goodness. There are other variables.
The July 1969 issue of Stereo Review measured a half dozen cartridges. The three best (subjectively) really didn't measure that different from the rest, with the possible exception of stereo separation. It is an old article, but interesting nevertheless. Some findings, using the SME 3012 tonearm:
One of the top 3 subjective best cartridges, the ADC-25 ($100.00) which came with 3 different styli, sounded the same regardless of the type of styli that was used (.03 x .09, 0.3 x 0.7, 0.6 conical).
The ELAC STS 444-12 ($60.00) was one of the top 3, in spite of FR which was similar to the other cartridges.
The el cheapo Grado FTR ($9.95) had a rising (10dB) response at 15KHz, but sounded as good as the expensive cartridges.
In casual listening, it was difficult to tell among the group (which also included Stanton, Pickering, Shure, Empire).
Apparently there are some issues with this new turntable and Schitt are offering to refund customers or offer the fix + $300. Anyone know anything about this?
