Most likely is that the Windows volume controls for input and/or output are set differently. Should also check that the View preference "Full scale sine rms is 0 dBFS" is set the same for all installations. Probably better using ASIO drivers to remove Windows audio settings as a source of differences.
Noted. Thanks John! I will check that.
