Review and Measurements of Totaldac d1-six DAC
firedog
Low volume production will increase cost, and amortizing the cost of development over a small number of units produced can inflate prices massively.
However, even recognising that, the cost of this DAC seems excessive. Benchmark are also a relatively low volume producer I am guessing, I also suspect that their production also relies on non-automated processes. Yet they cost an awful lot less and clearly they are the result of development and design of the highest order. I have no idea how much it costs to make one of these TotalDAC products but the only way it could get anywhere near justifying a 13000 euros price would be if product development and production is grotesquely inefficient. I suspect it is more likely that the manufacturer knows there is a niche market which equates price with better sound and exclusivity and has just positioned themselves to serve that market. From a strictly business perspective it is quite a smart move.
At a deeper level though, if you have a product which has been commoditised in the way that DACs have been (as evidenced by the Apple dongle or the multitude of excellent DACs costing less than a twentieth of the price of this) then I think it hard to justify the price of this unless it is viewed simply as a statement and audio jewellery. The problem is that it is built like alternatives costing a few hundred dollars or less (actually the March Audio DAC has much better design and casework for a tiny fraction of the cost and is also made by a small supplier).
In this segment price is meaningless as nobody buying this is applying rational analysis of performance and cost, but given you can buy some lovely audio jewellery at that price I don't know why anyone would buy this.
Don't disagree with anything you said, but when the company principal and maybe one or two other people do all the work in a high priced Western economy, they have to make a lot of profit on each unit to make a living. It's not just "cost". I'd assume payback per hour for Vincent to decide it is worth it to employ himself is very high. I don't think he's doing this to live at minimum wage. And as you said, in this market sector you can pump the price up and it may actually increase your sales. For certain segments, a higher price increases sales, instead of reducing them. His least expensive DAC is not his best selling one.
firedog
In professional circles, ABX is widely regarded as being the gold standard of test methodologies when you need to compare a new process or method with an established approach. I really do not see why audio amateurs bear such a grudge to this reliable and proven method.
That's actually a myth. Testing methodology is highly complex, and even seasoned scientists will employ specialist experts to properly design tests. Only on forums is ABX- double blind talked about as the generic "gold standard" for testing. It isn't. In professional circles there are lots of testing situations where ABX isn't considered the best method to test a hypothesis. Look it up sometime.
Dialectic
a fortified compound
Please let us know where to look it up.
firedog
Get some texts on testing methodology. I've read some (in the past). Testing in fields other than medicine, (where randomly assigned groups and blind testing IS often used) uses all sorts of methodologies. You can spend your own time educating yourself, instead of using mine.
zalive
Well, anecdotally, experience of the local audio cable manufacturer is that his best selling products (70% of sales quantity) are the most expensive ones.
None of his products is actually cheap, his entry cable is not cheap. So what happens is that lot of his customers act at 'cost no object' principle, because such are customers for expensive cables. They simply want the best, so they buy the TOTL product. His 'entry' line sells least (10%).
Dialectic
I had a feeling a non-answer was forthcoming.
firedog
No, I'm just not interested in doing leg work for arrogant people who appoint themselves some kind of "scientific" expert, and don't have a clue about how actual science works.
The non-answer is yours: declaring a generic all encompassing "gold standard" for testing, when if you were honest, you'd admit you have next to zero knowledge of how testing is actually done in all sorts of research situations, especially many dealing with perception. Please show us YOUR basis for declaring as a fact that ABX/double blind/randomly assigned is a recognized gold standard all across science. It's generally used in drug trials, but even there it is acknowledged not to eliminate all bias/expectation and to have limitations. And not all testing is the same as drug trials - other types of research employ different methods.
Pluto
Harrow, UK
That's actually a myth...
Well, you had better inform the AES, EBU etc. of the fact that they got it all wrong.
Chances are that several things you listen to these days were developed in conjunction with, or out of, listening tests in which I participated. So on their behalf, I apologise for their ineptitude and suggest you write to both institutions offering your undoubtedly wise counsel when it comes to the development of innovative techniques and standards.
Dialectic
The non-answer is yours: declaring a generic all encompassing "gold standard" for testing, when if you were honest, you'd admit you have next to zero knowledge of how testing is actually done in all sorts of research situations, especially many dealing with perception. Please show us YOUR basis for declaring as a fact that ABX/double blind/randomly assigned is a recognized gold standard all across science. It's generally used in drug trials, but even there it is acknowledged not to eliminate all bias/expectation and to have limitations. Not all testing is the same as drug trials.
Please take 10 seconds to name for us a scientific domain where something other than double-blind testing is used to establish whether humans can tell a difference between two non-visual external stimuli. Wine and gastronomy are not acceptable answers.
Thanks in advance for your very valuable time
THW
i have a feeling this is going to also mean we are to trust the colourful descriptions audiophools like to use when describing DAC differences.
firedog
Another BS response. AES is not a serious organization, sorry.
And again the claim was that ABX it THE research gold standard. Please prove that claim. Your anecdotal experience (whatever it is) doesn't do that.
KSTR
Berlin, Germany
IMHO the pre and post ringing is caused by an internal upsampling option (SRC in FPGA) that is never totally bypassed, even if deactivated. The ADI's don't show any in NOS mode.
Understood. So the shown response is a result of preprocessing in front of the DAC chip proper.
FrantzM
Hi
I don't think it began with ASR. Yet there is something compelling about the tests run by Amir and others at ASR: They are based on standards, Industry standards and they are repeatable. If someone disagree with a result he/she is free to run it and show the discrepancy. That is not what happened in the TotalDAC thread.
I though that the effects of ASR tests would be slight, after all, we have witnessed people whose personal experience with blind tests or level matching, could not dissuade them, e.g. blind tests, yet revert to their old ways.... This is not the case, ASR profile is rising and with it questioning about some well established practices in High End Audio Industry. The eternal rise of prices for no improvements. e.g. It is very difficult for anyone that has a modicum of electronics knowledge to find much value in the very expensive power supply of the Total for example. If one didn't know, fine, but once you know ... and now we know... Other will know. They will question and the product will have to improve or face the questioning... which rarely result in increase sales.
The well is drying. As much as the Internet brought them riches it is also carrying a large amount of dissent and of questioning that won't always be addressed with "Trust ME" ... We're living in a world where information is available. A good portion of High End Audio companies feeds on the beliefs (and insecurities ) of audiophiles. The pendulum seems to be swinging in a different direction now, people wand to be reassured of the validity of their purchase by something objective, by repeatable measurements, by metrics.
High End Audio almost took pride in saying that measurements don't count ... this line of reasoning is wearing thin. It is getting uncomfortable up there :)
KSTR
Berlin, Germany
Btw. do ADIs implement anti-sinc roll off compensation respective for NOS or filters which might need it?
Mathias (MC) has posted the neede settings for the on-board EQ to achive anti-sinc precorrection somewhere on the RME forum. Also, you don't need to pay TotalDac's 10% markup for a (fixed) bass boost option, it comes for free and is flexible... ;-)
THW
not even sure what your point is arguing about whether or not the ABX and blind test in general is “the gold standard” other than to cast doubt on the useful of a blind test.
to me the important thing is, do properly conducted blind tests provide us with useful data? in my view, everything so far suggests “yes”.
zalive
ABX is a specific testing methodology. Not the only one for DBT.
My knowledge on DBT methodologies is still really limited though.
What I have come in my mind to be possibly the best methodology might be similar to what someone called the AX.
Two systems in a single experiment. One is A. X can be either A or B. You answer whether you're hearing the same sound or a different sound.
Much lower complexity than ABX.
not even sure what your point is arguing about whether or not the DBT is “the gold standard”
Don't use a strawman, @firedog specifically talked about the ABX, not about DBT as such.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
So, in other words..."I read it somewhere" is the best you've got?
One of the things that I appreciate about this forum is how the discussions are often loaded with references, graphs, thorough logic, etc. To participate in the discussion often means to further educate others who are participating so they can follow along as they choose. The old...'because I said so,' or 'I read it on the interweb,' isn't going to convince a lot of people of anything other than you just can't support your claim.
pkane
North-East
I’ve done a bit of research into this, primarily because I felt ABX was unnecessarily complex to detect small differences.
But, this conversation is probably much less about ABX specifically, and more about blind testing in general. A double-blind test is absolutely a gold standard in eliminating known biases. Randomized samples help perform the ‘double’ part of a single blind test, and so are useful in reducing certain kinds of errors in testing. There are many other kinds of blind testing. Some are designed for detecting large differences, others - small.
Regardless of the type, blind testing is necessary when it can help control for well known sources of bias.
sweetsounds
Just marketing guy or rather Used Car Salesman?
Well no actually. This guy has obviously no focus on marketing or public relations. He probably just lost a good part of future customers, but doesn't care (his response to the concern "People might buy less NOS DACs because of these measurements" was "Great, that means less competition").
He is an engineer with the fixed idea to build the best possible ladder DAC, regardless if it makes sense to us to build such a DAC at all.
If you measure his masterpiece "wrongly", he treats you like an incapable.
He would react to the quantization noise with "don't tell me something which was clear before you opened your mouth. This was never the point.".
