Huh? I use mine via USB with no power supplyTopping D50 needs external power supply in all modes, usb too.
Yes, but that's not what he meant. The thought previously was even when using USB, you needed an additional power supply. Myself and one or two others confirmed that not to be the case.Power supply by USB connection, it is also external power supply.
you are right. I had hooked up two components since getting my d50 and had forgotten there are two USB cables in the box. it comes with two, one for data, one for power. my original thought was for those talking about buying an additional power supply and as long as you have two open usb ports - you don't need to do that.No no, that wasn't the point. The point was the topping D50 is using usb connection only as data connection not as power supply. To power up the Topping you have to connect ADDITIONAL connection via attached barrel 5V to usb cable (it is in fact external power supply connection).
Amirm thanks for the reply, i'm planning to buy on 11/11 Black Friday, At the moment i have nothing on the balanced side but i'm planning to...SMSL is supposed to send me another sample soon. There may be some improvements there so you may want to wait for that.
Until then, do you have headphone or power amp you are driving with balanced input? If so, SMSL SU-8 would get my vote.
