Review and Measurements of Topping D50 DAC
chosen_too
Ok, paired topping with Allo digione, screen goes off nicely, sound changed also, but can't say if it is better or not.
chosen_too
Yep, that's it. When there is no signal from digione - dac goes to sleep, with USB connection dac never sleeps.
Jimster480
Tampa Bay
Ah, yea it could be because of the other device that Topping devices usually use in their USB connections.
I know my DX7 has 2 devices that appear in device manager.
chosen_too
I tried some tricks to autosuspend USB port, but without success. Anyway Digione sounds different than USB, bass is less boomy, sound is thinner overall. Maybe it's another software glitch and I need to reset everything again.
chosen_too
Maybe the driver for that is downsampling?
Ehh, I'm such a dumb ass. Figured out how to turn off topping's screen over USB, so device is active, but OLED screen is off which is fine for me. Both second and third settings must be "auto" in main menu.
I'll try to compare sound over USB and coax now and report.
Jimster480
Tampa Bay
Awesome!
Let me know how the testing goes!
chosen_too
I must admit there is difference between USB and Digione. USB sounds much better - rhythm, clarity, bass, more detailed sound. To be sure I asked my wife to assist me in blind test, difference is obvious for both of us.
I heard a lot from Digione users about better sound from BNC output even using BNC-RCA adapter, something with output levels, I'll try this later maybe, but for now I'm very pleased with USB connection and see realy no reason to buy special HAT for Raspberry.
USB much louder also, alsa mixer untouched though.
Darwin
It’s back on Massdrop for $199.
Weird they don’t have a matching Amp.
Roen
On Aliexpress, for Singles' Day, I managed to snag it for $186.99.
Peib
Spain-Andalusia
I saw this photo at headfi from an user who was in the canjam shangai
There will be an external powe supply too, P50
Veri
Damn, awesome! A50 still coming, then :) another contender against the JDS Atom, ha.
I wonder what the BAL port is. 2.5mm balanced? 4.4mm???
Peib
Spain-Andalusia
it looks like 2.5mm, but im not sure
anyway it looks beautiful
the only problem i see is about the power supply. It will probably cost more than a hundred
