So far, even reliable measurements of the frequency response for all filters have not been given.Is the SMPTE Intermodulation Distortion the same for all DAC-settings (mode1-7)?
It should be fine. The 4A is maximum current. The device wont pull more current than it needs.Getting impatient waiting for my power supply to come. I have an O2 Joggler that has a 5V 4A power supply. Is this ok to use? Is 4A too much?
Is the "linear" power supply used for testing a premium unit? What should one expect to pay for one?
Awesome, thanks!Not sure about Amir's lab unit, but if you look all the way back to page 2, post #23, you'll see that he also measured this unit using the USB power from his laptop and did not get significantly different results.
Do you do digital volume control before the dac, and might be in the ”ESS IMD Distortion Hump” trouble levels?I'm experiencing a strange effect with this dac, there is great fatigue when listening to it. My setup consist of Elac 207.2 speakers, Primare a 30.1 amplifier and raspberry pi 3 with topping via USB, volumio installed, music Redbook flacs mostly. When I'm switching to Allo boss sound getting much less transparent, but I can listen to it for a long time without any headache. Raspberry powered by Samsung PSU, Topping is connected to decent Mean Well Smps. My wife sharing same experience. Maybe there is some special tips and tricks for topping and raspberry?
You are used to other devices that are significantly rolled-off then... "agressive" is a weird way of describing transparent.Digital filters don't solve my issue completely, very aggressive sound so far. I'll try too pair dac with my windows laptop on weekend, hope this is software issue.
Wish it was that simple =) I have nothing against tranparency, but listening fatique in my experience always connected with some kind of distortion. For example previously I used Lavry DA10, Apogee Minidac, Benchmark DA1, some E-MU and ESI cards and none of them caused such problem.
Try to connect Topping to cd-player and check if the sound differs.
