@Neddy
Sorry for the late reply.
I don't have another Vanity board. I actually feel fortunate as about a year ago I considered selling it. Happy that I didn't follow through!
I actually haven't employed it for two years or so. I tested it to make it sure it was still good before I ordered last month.
I used it initially to support 3 Gustard DACs for a 5.1 configuration (NUC>>Oppo>>Gustards). Worked just fine, I was happy.
But then I discovered I2S and changed my entire front end to a PinkFaun streamer with an I2S MCH bridge. Love it. PinkFaun>>2 Matrix Sabre Pros and a Topping DX7Pro.
I have ordered the Okto8 to replace my Emotiva XMC-1 in HT duties. Still undecided if I will use the AES/USB option or stick a miniDSP DDRC-88D in the middle. I will begin with option 1 and run my EQ/DSP through the streamer/JRiver. If needed, I can add the miniDSP.
If I really like it, I can also use it for Computer audio duties and eliminate the I2S and above 3 DACs. Or not.
Here is an Audiopraise email, which I think is still active. His name is also Pavel and he's a good dude. He is working on an I2S device and I have signed up to be a Beta Tester for him. [email protected]
Stay healthy and play it loud!
Thanks very much!
You have a much more complex setup than mine - is the dual Matrix Sabre system also 5.1 ch?
I was looking at the Sabre's closely, but were way out of my price range.
I'd been following the Okto I2S DIY projects, but wasn't in the mood for more DIY, so the timing of the DAC Pro release was great for me.
Timing seems critical on Vanity board availability I missed them going out of production by just 1 year, and missed the few that have come up for sale since by about the same.
Thanks for the contact info, I'll drop Pavel a line - worth a try anyway, as those things are rare as hen's teeth.
I'll be interested in your impressions of the XMC1 to Okto upgrade for sure. (I remain GobSmacked with how good it sounds.)
I'm using a PC/NUC/JRiver/PowerDVD with the DAC Pro in USB mode, which works great, but getting properly Mch decoded HT/Bluray into this system is a nightmare - so the Vanity/Okto AES option would be IDEAL....and would be SO simple to switch between that and USB.
If for any reason you choose not to use your Vanity/Oppo, please let me know!
Ah, LOUD - definitely!!! DAC PRO does that very nicely
Thanks again!
