Same to me !My atom psu also broke, I glued it back with epoxy.
It looks like a very brittle plastic.
We notified the OEM of this EU/UK construction deficiency in 2020 and it has been resolved as far as internal statistics show. Please do not hesitate to ask if you need a replacement. We have covered replacements for everyone who has inquired.Mine also broke at the plug (Euro version).
It's easy enough to fix, but a thicker case or one made from another polymer would probably be a good idea.
Thanks for your answer !We notified the OEM of this EU/UK construction deficiency in 2020 and it has been resolved as far as internal statistics show. Please do not hesitate to ask if you need a replacement. We have covered replacements for everyone who has inquired.
I've noticed the volume knob on my JDS Labs Atom Amp is also coming loose, it gradually works it's way down the shaft, and I have to keep pushing it back on properly every few weeks. I think it's just come unglued or something. I mean it doesn't really bother me, I suppose it would be better without that happening, but in reality it makes zero difference.Have owned this amp for more than 2 years and couldn't be happier with it's performance.
Today I noticed the volume knob was loose and crooked. TBH it's likely someone in the household damaged as opposed to manufacturer's defect. Within 2 hrs of sending an email to JDS through their web help section, they had a new knob in the mail.
Awesome customer support to go with a great product!!
I replaced mine with a mixer knob (fatty knob - https://store.djtechtools.com/products/chroma-caps-knobs-and-faders), with similar ones available for next to nothing at music stores. Looks a bit ugly, but functionally it's so much better than any normal volume knob you'd find. I also tried the knurled metal knobs, but something about how easy it is to use the mixer knob made me keep using it instead.I've noticed the volume knob on my JDS Labs Atom Amp is also coming loose, it gradually works it's way down the shaft, and I have to keep pushing it back on properly every few weeks. I think it's just come unglued or something. I mean it doesn't really bother me, I suppose it would be better without that happening, but in reality it makes zero difference.
Yes, the main ergonomic problem with the JDS volume knob is that it's not quite deep enough to grip properly, which is probably why it eventually worked loose with use - as lateral pressure is exerted when I grip it as my fingers push up against the housing therefore applying small force to push the knob away from the housing.....a longer knob would mean my fingers wouldn't contact the housing and therefore no lateral force would be applied to drive the knob away from the housing, lol, don't worry I've not spent ages thinking about this, it just seems quite obvious to me how it happened, lol! Will they just slot on? Perhaps I could google mixer knobs on Amazon or something. I mean it looks better with the orignal knob, but I might replace it if it starts coming loose every few days instead of every few weeks.I replaced mine with a mixer knob (fatty knob - https://store.djtechtools.com/products/chroma-caps-knobs-and-faders), with similar ones available for next to nothing at music stores. Looks a bit ugly, but functionally it's so much better than any normal volume knob you'd find. I also tried the knurled metal knobs, but something about how easy it is to use the mixer knob made me keep using it instead.
The mixer knob did not cover the ring, but it didn't bother me as everything about the knob, gap, and light were uglyYes, the main ergonomic problem with the JDS volume knob is that it's not quite deep enough to grip properly, which is probably why it eventually worked loose with use - as lateral pressure is exerted when I grip it as my fingers push up against the housing therefore applying small force to push the knob away from the housing.....a longer knob would mean my fingers wouldn't contact the housing and therefore no lateral force would be applied to drive the knob away from the housing, lol, don't worry I've not spent ages thinking about this, it just seems quite obvious to me how it happened, lol! Will they just slot on? Perhaps I could google mixer knobs on Amazon or something. I mean it looks better with the orignal knob, but I might replace it if it starts coming loose every few days instead of every few weeks.
EDIT: would these fit, they're black & would look ok?
Tbest potiknopf gitarre,Volume Tone Knobs, 10Pcs Guitar Bass Volume Knob Durable Potentiometer Volume Tone Control Knobs s replacement for D Shaped Shaft Electric Guitar Bass : Amazon.co.uk: Musical Instruments & DJ
Tbest potiknopf gitarre,Volume Tone Knobs, 10Pcs Guitar Bass Volume Knob Durable Potentiometer Volume Tone Control Knobs s replacement for D Shaped Shaft Electric Guitar Bass : Amazon.co.uk: Musical Instruments & DJsmile.amazon.co.uk
EDIT #2: yes, measured the knob on the Atom Amp, same spec, would fit.
EDIT#3: the overall diameter of the knob is less though so you probably wouldn't get the nice subtle ring effect of the white led behind the volume knob - the narrower knob would make the ring effect wider & brighter, which might be off-putting. At least I know what size volume knob to get in the future if I need to replace the existing one....I might try putting somekind of "gunk" (very small amount of blue tack?) on the shaft to get the original knob to fit tighter.
audiosciencereview.com
The aluminum knob I purchased off aliexpress, from my recollection, was a perfect drop that worked with the ring light. I just noticed JDS sells an aluminum knob on their website and provides the dimensions (if JDS distribution is limited in UK). https://jdslabs.com/product/black-aluminum-knob-taiss/
Edit: Earlier posts had some knob discussions
Review and Measurements of New JDS Labs Atom Headphone Amp
All the praise this amp is getting made me decide to try one for myself, got a choice of the Topping D10 or D50 to match it with, should be fun, and might make me think more about selling off more of my "high end" stuff if it powers all of my headphones nicely.audiosciencereview.com
Yeah, thanks for that too, prompted by your link to the jds labs shop for that aluminium knob, I managed to find one on Amazon immediately that will of course be delivered within the UK here (whereas JDS Labs shop is in the USA), it looks identical to the Taiss knob:The mixer knob did not cover the ring, but it didn't bother me as everything about the knob, gap, and light were ugly
Static electricity can build up on plastic and it can also migrate across surfaces to another location... very strange stuff static electricity is.Doesn't the metal knob introduce static risk like the L30 had?
And I think I have the same cable for HD560S.
I only ever touch my amp whilst wearing rubber gloves! Covid / STD's and other pyschological issues.Doesn't the metal knob introduce static risk like the L30 had?
