Review and Measurements of New JDS Labs Atom Headphone Amp
Tortie
Finally had an opportunity to listen to the Atom with my Sony Z7 and pairing works extremely well. Sound is super clear and musical. The Atom has the right balance of detail and smoothness. For the HD650 I mostly use high gain. Gain is set at 0dB for the Z7 and it sounds fantastic at this setting which surprises me since every other amp I've used has never sounded good at 0 gain.
Veri
Thoughts on the Atom vs the Schiit Heresy pleez.
Atom with a replaced better knob will be smoother to use IMO. Power-wise they are quite close... Heresy knob can get scratchy (very small knob). Atom DAC+amp vs Heresy+Modi stack aesthetics is rather personal.
Fernando
Spain, Europe.
Hellos.
Has someone added weight to it so that it doesn't fly off or to be able to change headphones without effort and juggling?
cheers.
Tortie
Hellos.
cheers.
You could use 3M fasteners (interlocking tape) to secure the bottom of the amp to the shelf or desk underneath. This is an inexpensive and reversible solution.
GGroch
Denver, Colorado
Hellos.
cheers.
It actually does have 4 weights on the inside. I put my D50 DAC on top of it. I have used Tortie's idea, 3M slim velcro, in the past and that works great.
cryptout
I'm considering bridging and removing the volume pot. Did anyone already try this? (I prefer to use my D50s digital volume with remote)
King3567
I have a question as well, I have a couple of headphones and sometimes I will want to use a different amp - I know this has an output, can that feed into a second headphone amplifier, or will this cause problems? Thanks
Veri
Don't see why not, it has a preamp function on the performance level of the head-amp. So should be fine to use the way you envision.
King3567
thanks
the second amp is definitely higher distortion than the atom amp, so I don’t know really why I will be doing this, but I just feel like it. Ok. Gracias
Boris Badinov
The Humorist
Georgia, USA
A noob question here: I have a Cambridge Audio Dacmagic Plus sitting around doing nothing and just wondering if this would be a decent pairing with the Atom headphone amp?
Boris Badinov
The Humorist
Georgia, USA
Well, I don't know why I said Plus:facepalm:. I'm sure I looked at the box, but I have the DacMagic 100. Has that been reviewed here?
Edit: found it, measures close to the Plus. Same question, though. Would I be good enough with this or should I look for something better & more recent?
Thanks
AdamG
Moderator
Reality
