Hi all, I just wanted to give an update regarding the crosstalk at the lowest gain. It occurred to me, since I had to put the volume control at 4 o'clock in the test that had the crosstalk issue, perhaps it's the potentiometer that's causing it. So I did another test, this time with gain setting "2", with 20 dBu input and the volume set to 1-2 o'clock to reach 6 dBV output, and I get a similar, albeit lower, increase in crosstalk!
So it looks like the increase in crosstalk is caused by the potentiometer (and varies with the position of the potentiometer), and not the gain setting.
Hi, is this with single ended RCA inputs?
If so, is the same issue there with balanced XLR inputs?
Cheers
