Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
The thing is that balanced makes so much sense over long lengths, for example microphone XLR cables. MUCH less noise over those lines, unbalanced could have serious hum.Is this really some audible problem? I mentioned making a balanced cable from my portable Dac (Opus 1s, its has such type of connection mentioned in the manual, in fact) — to Amp connection at some other forum and got laughed at by many members, they say it's a marketing thing and I should not bother...
In our home set-ups, a cable run of 1-1.5m has much less chance of getting into any serious noise problems. Multiple RCA runs from multiple devices might end up with a ground loop somewhere, in which case balanced XLR can again have important benefit in such a run, but in simple use cases RCA is perfectly fine in which case one could indeed say it's a marketing thing.
From a theoretical standpoint no matter the length of cable run, balanced will be better though, but from a practical and budget standpoint there is less sense in going for the pricier balanced gear.
Andrew of the THX team said a simple RCA>XLR cable into a fully differential amp can already have some good noise reduction so fully balanced might not even be necessary with the right gear. Not all amps will accept unbalanced over XLR though! Also, some people will simply like the XLR connector that much more than the stiffer RCA/BNC connector ...
