Review and Measurements of Hypex NC400 DIY Amp
Julf
Amsterdam, The Netherlands
@rajapruk I'm looking at the pic trying to figure out what you mean by the inside of the screw-connectors. I oriented the speaker cables to go out the back of the NC400 in parallel with the power and input cable. Because the screw itself was in the way, I had to choose whether to offset them towards power or input, and I chose input.
The way Bruno recommends is actually one cable going one way, the other the opposite way - toward each other. That way the "unbalanced" area (that acts as an antenna) is minimized.
6speed
Virginia, USA
Oh, I see; that is a good suggestion. If I had enough slack to reorient the existing cables, I would make the change.
Hayabusa
Abu Dhabi
How do you see these monoblocks nc400 audiophonics compared to hypex kits in terms of chassis, components, internal layout? I just ordered two mono from soundimport at the same price.
Layout looks more optimal towards output/input connectors.
Case is also more compact.
But as SMPS and amp are 100% the same, I wouldn't expect any significant difference.
JimB
California
Nice build.
... wire both the internal speakerwires to the inside of the screw-connectors at the nc400 end...
I did that. But the build shown is not as bad as it might seem. The white wire is effectively 'paired' with the black wire where it passes over the black connector (assuming it is in contact). The open 'loop' area from white to black is then really small/short. It would be much worse if both wires exited 'up' from the PCB - that would make the open loop area is much larger.
batfunk
In stock now!
Does Audiophonics implementation look good to you by watching VintageFlanker attachments and graphs of the site? Any return about their components and building quality?
This could be my next amp. I like my teac ai-501 but this could be a vast improvement for my Paradigm prestige 85F.
By the way, could this amp be too powerful for my loudspeakers(200 watts max input, 89 dB at 4 ohms)? I've got a small room(3.6x4.3x2.5 meters) and my listening rarely exceeds 60db.
Thanks!
Julf
Indeed, the loop area is very small, the issue there is more the asymmetry.
6speed
Virginia, USA
Thanks!
Under normal circumstances, there is no such thing as an amp or a car that is too powerful. Your amp is only going to deliver as much power as you ask it to by turning the volume control on your preamp, similar to a car is only going to accelerate or cruise as fast as you tell it to by pushing the gas pedal. In your case, you should be looking at the noise and distortion performance of the first watt since that is all you will be using.
batfunk
Thanks for your answer!
Anyone about quality of implementation of Audiophonic's amps?
Julf
Yes and no. One could definitely argue that a car engine that breaks the gearbox and the differential if you use full throttle is too powerful. Likewise an amp that fries your speaker if played at full volume is, in my view, too powerful. Of course you could adjust the gain so that you nevetr use the excessive power...
VintageFlanker
Paris
Wow wow wow...
@Audiophonics strikes again: New MPA-M400NC (Monoblock). 699€ tax included. Same price as DIY kits from Hypex Shop, but assembled (and most important: available!).
The enclosure is similar to ones used with NC122MP and NC250MP, but wider. Still, I think there is a typo regarding width:
Dimensions 413 x 322 x 60mm
audiophonics-mpa-m400nc-class-d-mono-amplifier-ncore-1x400w-4-ohm (1) (1).jpg
audiophonics-mpa-m400nc-amplificateur-mono-class-d-ncore-1x400w-4-ohm (1).jpg
batfunk
Well, I missed it :p.I compare Thd+n vs power at 4 ohms measurement from Audiophonics with Amirm's one, the curve is the same. I'm a newbie,is something wrong about its other measurements?
Thanks!
Julf
How much voltage is needed to run this amp to it max ?
The Hypex NC400? 75 V is the absolute maximum, but they are really designed to work together with the Hypex SMPSs.
VintageFlanker
Paris
I think he was asking about the input sensitivity:
2.05V - 8.46dBu for 400W/4ohms - gain 28.5.
Julf
Absolute
I have a couple of Nc400 monoblocks coming next week and I have never really thought about this gain-stuff. For the time being I will be driving them with Minidsp 4x10hd using balanced output. According to the manual, I have a choice between 4v output voltage and 8v through a dipswitch on the board. How does this stuff work, what should I pick?
