This is a review and detailed measurements of the EVGA NU Audio PC Audio card. It includes stereo output, stereo mic and line in, in addition to headphone output. This is a collaboration with UK audio company Audio Note so expectations are high as far as its performance. As it should be as the cost was US $250 when I purchased it. I see a US $60 discount now on both Amazon and EVGA website bringing the price down to US $190 including shipping. That is still more money than Creative labs sound cards but hopefully the NU Audio performs better.
The card is still in my machine so sorry about the dark image:
The lights are RGB and nicely fade from one color to the other. You almost want to sit there and watch them. So on that front, they are nicely catering to typing PC/gaming enthusiast.
I can't crawl on the floor to take a picture of the connectors so here is a shot from EVGA website:
There are provisions for changing ("rolling") op-amps -- something I recommend staying away from.
It was a breath of fresh air to find proper RCA connectors in the back rather than 3.5 mm that Creative and others use for their cards. Same for the 1/4 inch headphone jack. Line In however is 3.5 mm as you see.
There is a solid shield on the card by the way and doesn't come "naked" like shown above.
The architecture of the unit is a PCI-E to USB interface and there, is a USB DAC and ADC. So essentially an internal version of what would normally sit outside your PC.
Base Windows 10 driver allowed the line out interfaces to work as is with the built-in class drivers which was nice. However, the output from headphone outs was very low (0.2 volts) and there were no Windows controls to change it. To fix that I had to install their driver package. The driver package was a fraction of the size of the massive crapware Creative throws at you which was nice.
Alas, the experience while not nearly as horrendous as Creative, was still rough. On first run of the setup, it asked me to reboot before installing the driver. Strange. After reboot it ran for a bit and then instructed me to connect the hardware. Connect the hardware? The board is still inside the machine. This is the same error message that comes from some USB DACs. There, you disconnect and reconnect the USB cable to get it to proceed. How the heck one does that here? You can't unplug the board, nor have access to internal USB.
I rebooted and tried again and while this time I did not get an error, I did not get any kind of control panel to change the settings either. One more reboot and all of a sudden the control panel popped up. There, there were independent headphone level which I maxed out for testing.
Amazing that in this day and age, Windows and theise IHVs can't properly expose simple features like headphone output.
One nice thing was an ASIO driver which I then used for all the rest of the test including ADC input.
DAC Audio Measurements
Here is our dashboard:
I was disappointed to see that the card cannot reach 2 volts output. It is not a big failing though as it is close enough.
Distortion is not competitive with the budget DACs we are used with harmonic distortion clearly visible. It sets SINAD to 98 dB which just falls short of the competent, green bucket of DACs we have tested:
I did however like the clean noise floor in the FFT.
Performance seems good across the board starting with Intermodulation distortion test versus digital level:
Linearity was excellent showing attention to detail:
Jitter had a few bits here and there but good, low noise floor and nothing of substance to worry about:
Our 32-tone test did not upset it either:
THD+N versus frequency was likewise well behaved:
Same story repeats with dynamic range:
But pretty large shortfall relative to spec which likely is from the DAC chip they use, rather than actual implementation (or a non-standard way of running this test).
Headphone Output Audio Measurements
Most important here is power versus distortion. First into 300 ohm:
That is very good amount of power, beating even Topping DX3 Pro. Sure, noise and distortion is higher but that has been the same story so far.
33 Ohm load upsets the card to some extent though:
Was disappointed to see one channel get a lot worse than the other. Likely has a less optimal path to power supply.
Still, on the audible part which is power, there is plenty of that here to the tune of 1.1 watt.
Both of these predict very good subjective headphone listening with ability to drive majority of headphones in the market with ease.
Output impedance was comfortably low:
ADC Audio Measurements
I started to expand my tests for analog to digital converters. Let me know if there are other tests I should develop.
Here is our dashboard view:
Max level is reached around 1.9 volts input. 2 Volts saturates and creates distortion. Unlike the DAC, we have a lot of noise components in FFT spectrum. They are well below the distortion products though and overall SINAD shows good results:
That is a big step above Sound Blaster products. And oh, someone had asked me about Behringer. You see the SINAD results above. The EVGA NU Audio beats that too by a good margin.
Dynamic range likewise exceeds 16 bit audio:
Here is THD+N versus level:
We have lower noise and distortion than Asus Xonar U7 MKII.
Linearity is not that great but much more well behaved than other PC cards:
Nice that the capture just gets noisy rather than producing garbage or quantization noise (steps).
IMD versus level is new so no reference:
You can see the saturation at near 2 volt input.
Frequency response was flat to 20 kHz using 44.1 kHz sampling:
The mention of Audio Note implies high-end audio performance which EVGA NU Audio fails to achieve. All is not lost though. The hardware implementation of DAC, headphone output and ADC are very good. You can do better at lower price on the DAC side. But it is impossible to get all three at this price using desktop hardware based on testing I have done so far.
The main issue is software drivers and hassles of PC. If you can get past that, I can recommend the EVGA NU Audio at its new price.
Something tells me this card is not selling well and hence the $60 discount. The PC market is very price sensitive. So if you want it, you may want to buy it now before it goes out of production.
This card is available for sale if someone wants it.
With taxes, I paid nearly $270 for this card. Please donate some money so I don't stay depressed for long using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
