I think the original review left some members at a loose end because the best measurements were obtained using Roon.
Subsequent posts requested that Amirm test the CCA directly from Tidal to rule out any influence that Roon could have on the results.
Unfortunately, I dont think his ever happened, even though Amirm found test signals on Tidal.
Hope it’s not too late!
I believe the conclusion was casting from chrome was horrible (eg tidal Web app) but that Google had provided app/sw providers with the relevant info to enable bit perfect. I assume the tidal app is one such, with many others.
I work on assumption that if the app has casting enabled in the app, it should by now be but perfect.
CCA into D30 sounds a lot better than CCA analogue out
I have been conducting these tests on various DACs using a playlist which I am quite familiar with.
The CCA analog output wasn't exceptionally good though IIRC?
In my personal experiences the "linearity" test has had the largest impact on actual SQ when I compared different devices.
This is in regards to devices that I listened to and made my own judgements of before they were tested here by Amir (thus there was no measurement bias to go on).
I'm choosing CCA as listening device from my iPhone X's Spotify App
Depending on the nature of the files streamed by Spotify, Spotify may be the limiting factor in audio quality; is it streaming better than MP3?
Of course level matching by ear, it took me sometime to match the levels as I can distinguish more evidently on my headphones. And later it became clearly evident on my speakers as well. I am sensible audiophile, don't spend money on flagship gear or new releases, did learn it the hard way but that's what this hobby is all about.So no level matching?
It is not the way.level matching by ear,
It is not proven though, you are still assuming here. By the way, I did the same ear matched A/B tests with Topping NX4DSD and Chord Mojo and couldn't distinguish between the two and decided to sell Mojo afterwards. Like I said I trust my ears with the aid of technical information. I did a test right now on my speakers and the clarity coming out of D50 as compared to CCA analogue out is on a different level. You don't have to trust my assessments and judgements, if you are happy with CCA analogue out then you can save even more money. Good for you.IMO In a double blind test with equalized levels there is no way to differentiate the analog output of the CCA and the rme adi-2 pro.
No, in fact my CCA is connected to the RME.It is not proven though, you are still assuming here. By the way, I did the same ear matched A/B tests with Topping NX4DSD and Chord Mojo and couldn't distinguish between the two and decided to sell Mojo afterwards. Like I said I trust my ears with the aid of technical information. I did a test right now on my speakers and the clarity coming out of D50 as compared to CCA analogue out is on a different level. You don't have to trust my assessments and judgements, if you are happy with CCA analogue out then you can save even more money. Good for you.
Premium is 320 kbps ogg vorbis. Standard is 160 kbps.
At least you agree that ear can differentiate the clarity and qualityDoesn't work. The ear doesn't perceive small level differences (1-2 dB) as volume differences, but a difference in "clarity" and "quality".
