dallasjustice
It doesn’t have anything to do with your post because you’re under the erroneous impression that the DAC3 has 14 bits of resolution.What does any of this have to do with my original post?
Amir posted that just to match the output voltage between the topping and the benchmark. To do that, he had to greatly reduce the DAC3’s output. It helps a lot if you start reading at the beginning of the thread.
I read and understood it thoroughly, to the best of my ability. I suggest you do the same. None of your responses have been useful, relevant, or correct with respect to the remark I made in the first instance.Amir posted that just to match the output voltage between the topping and the benchmark. To do that, he had to greatly reduce the DAC3’s output. It helps a lot if you start reading at the beginning of the thread.
FWIW, it's already been pointed out that there appears to be an error in the comments on the above graph: 92/6 = 15.3 bits, not 14
Where’s my bloody tea?! Get along amir , and don’t forget the digestives like last time..
No matter how much you berate amir he never learns , he’s a terrible man servant ..
I recall recent less than stellar measurements of another DAC using the SE outputs (can recall the name) and the manufacturer was thoroughly pilloried, tarred and feathered and dragged through the mud by the group.Don't know if I'd call it a 'sad showing', since measurements from the balanced outputs are excellent. However I agree that the unbalanced measurements are not what I'd expect from Benchmark (I own the AHB2 amp) and quite puzzling given given their pursuit of perfection in measurements.
Without undermining the results, given that Amir was unable to enter calibration mode from the usb input I wonder if this sample may have been faultly in some way? It would be interesting to test another sample and see if the results can be corroborated.
I can't see anything in JA's Stereophile measurements that would indicate the above issue - but maybe he didn't do a similar test from the unbalanced outputs?
JA's comments on resolution are more similar to Amir's balanced result:
"When the DAC3 decoded dithered 16- and 24-bit data representing a 1kHz tone at –90dBFS, the increase in bit depth dropped the noise floor by more than 30dB (fig.5), indicating that the Benchmark's resolution is at least 21 bits. This is as good as a DAC can currently get!"
I see also that JA tested the 'HGC' version which is slightly different in that it parallels 4 channels of the 9028 dac vs 3 channels for the 'DX' version that Amir tested. Though this is unlikely to influence the unbalanced linearity in isolation, maybe the other differences between the models has compromised the unbalanced outs in favor of the balanced outputs?
So people should not be able to discuss things on a discussion board?That's why we need Amir HRH to resolve the controversy and then lock down the thread.
I don't think so.Amir posted that just to match the output voltage between the topping and the benchmark. To do that, he had to greatly reduce the DAC3’s output
He seems to be suggesting he's the 'anti-purr1n' - lol![]()
I hope not! DAC3's unbalanced output is much better:I feel this has a chance to become another "Yggdrasil" thread.
There will be disagreement, it’s healthy. Males are naturally competitive ( and aggressive), this shows at times in the way they compete for the supremacy of their ‘ POV’on the forum. I would be creating a ‘ artificial ‘ space if I were to eradicate this , that space would end up being dysfunctional a bit like giving us a lobotomy.I do fear that we will have to ask Amir, his highness, the king of audio, to resolve the argument between Messrs. Justice and Derp1N.
Pssssst..........................don't tell Cosmik about the listening tests.There does seem to be disparity between the balanced outputs and SE wrt this device (im sure I remember folks suggesting this could be true of other devices we have tested) so maybe it would be worth looking at this phenomenon in other devices , Speculate on the causes and god forbid conduct some listening tests on a extreme example to see if these discrepancies are audible.
