Revel F208 Tower Speaker Review
Absolute
Well, no. :)
What I'm speculating is that precise MMM measurement would follow PIR on any listening distance. So I'm basing my EQ on in-room MMM measurement, not on the single sweep or a bunch of them, as most EQ automated systems do but instead of MMM RTA with pink noise. I am also speculating that such correction can be full range as PIR (resembled with MMM) takes into account LW/ER/SP so it is safe to do speaker EQ based on it and not only room EQ in the modal region.
Such EQ is supposed to make best of your speaker but, as it wouldn't of course affect both DI curves, you are still left with the same directivity indexes. However, as not only LW but both ER and SP are potentially smoothed this way you can expect significantly better sound .
Above transition area you're likely correct. Whatever distance above minimum you end up with the predicted in-room response. My speakers look the same at 60 cm, 1m and 3.5 m above a certain frequency with MMM. I don't have spins for my DIY M2, so can't really confirm that, but you look to be correct. I'll measure now and confirm my own statements!
Absolute
70 cm, 1,5m and 3,2 m;
Pink Noise PN RTA MMM- 45 averages each
QMuse
Well, they do kind of change slope as distance increases, but not that much as I expected. I'm guessing this could be because of specific charateristics of your tweeter.
Unfortunately there is no PIR to compare them with.
Absolute
The slopes differes a little bit from standard M2 anechoic measurements because I don't have enough EQ points to add the small input-peqs of the original dsp. That's mostly around the 900-1500 hz area. Close enough me thinks.
And I like MMM, much simpler and faster than any other method.
QMuse
So you measured corrected response?
Absolute
No, there's no speaker correction involved here. Only the original dsp settings to make the M2 flat anechoic. Otherwise it falls off by 10 dB above 5k and below 200 hz. Think of it as replacement of a passive crossover filter.
BYRTT
Denmark (Jutland)
Are those charts empty or I need another coffee to wake me up? :D
Yes empty and perfect :p...but using a single normal tweeter piston the tweeter performance we see there is hard to do real world, looks it takes a low 12mm diameter piston to get half space coverage up there at 20kHz and SPL in those micro size or lower will be much too low.
.....@BYRTT is there any way you can simulate how PIR changes with distance relative to LW, ER and SP?
One can change Z-axis relative to microphone in VituixCAD and it looks like below, but while it looks okay take it with a grant of salt how spinorama plot looks other than SPL of on-axis curve, because think feature is mostly there to model a stepped baffle or so and that is much less numbers than what we use in below model, also we shall remember data is based Amir's spindata which is suposed to be at 2 meter and SPL at 1 meter as CTA2034 call for.
QMuse
If I'm seeing right in your simulation PIR's slope indeed increases with distance. Is that correct?
QMuse
@BYRTT Can you plz post those 7 PIR's from your simulation on a separate graph so it is visibe how they relate to ecah other?
Absolute
I'd love to see someone with the Revel F208 measure the speaker with MMM at various distances to see how it compares to the Klippel spin. Anyone here have that capability?
QMuse
That is exactly what @carlob is doing. Look at previous page where I comapred his measurements with predicted in-room response (PIR) from spinorama.
Absolute
Sorry, too much stuff going on. I looked a little closer into that small smiley-curve that I measured with my speakers between 1k-5k and compared to measurements of F208 because it looked familiar from other Revel F208 measurements.
Looking closer at these measurements and @carlob 's measurement I think we can conclude that the Klippel spins of Amir is accurate. Bumps in all the right places.
Revel F208 Twoer Speaker Spinorama Harman frequency response audio measurements.jpg
Revel F208 Twoer Speaker Spinorama CEA2034 frequency response audio measurements.png
QMuse
Well, you can't really directly compare spinorama responses to in-room measurement, except for the PIR. And that is what we are here trying to establish - how well does in-room MMM measurement correlate with PIR.
