Yes it does, without a doubt. It’s literally turns into a mobile phone speaker. You of all people should know this since you never recommend speakers that roll-off above 100Hz because it always sound bright to you due to the lack of sub-bass.No. The Predicted-in-room response is excellent above bass.
Think of it this way. Take a perfect speaker that has 20 to 20 kHz response. Then high pass it at 200 Hz. Does it become a terrible speaker?
Crossover at 180-200Hz with a subwoofer also means that the distance between the speaker and the subwoofer should be extremely low, as in the center speaker should be placed on top of the subwoofer which is not going to happen.
This recommendation is honestly against everything that you preached in previous reviews. Your standards for center speakers must have really went down after the last few reviews. It honestly doesn’t make sense to recommend a discontinued product anyway.
