Recently managed to get a couple 4-year-old Nord NC500 monoblocks for $300 each. Lucky me! I think they were well cared for by the previous owner.
The problem is that due to strict WAF requirements in my application, all gear needs to live in a small IKEA cabinet, including the amps. No ventilation here, the cabinet has doors which remain closed.
After leaving the amps on for a few hours on a hot (~30C) day, the housings felt like they were around 60C, quite hot to the touch but not enough to burn your hand. Too hot for me to feel comfortable about it. IIRC idle power is around 12w each, which is low, but that will gradually add up if there is nowhere for the heat to go.
I've invested in some case fans to add to the back of the cabinet which will run while the amps are on.
Does anyone know what (case / ambient) temperature I should target to not harm the amps' longevity? I have an infrared thermometer to check with, basically wondering how fast I need to spin the fans to keep the amps happy.
Related: Is it OK to switch the amps on/off using the surge protector, or should I use the switches on the front of the case to be safe?
