Sokel
- Joined
- Sep 8, 2021
- Messages
- 6,127
- Likes
- 6,204
Probably because it has EQ,high-pass filters,Room correction of some kind,etc.How would that be a useful option?
I had a look and it looks basic though.
When the drivers are vertically separated there are valid reasons to make the crossover slopes asymmetric and to consider delaying the lower driver, as part of balancing the directivity.IF the speaker has the drivers set up correctly, which means complementary acoustic summations.
Hi fluid, if by directivity you mean horizontal directivity, I think asymmetric slopes and delaying the lower drivers,When the drivers are vertically separated there are valid reasons to make the crossover slopes asymmetric and to consider delaying the lower driver, as part of balancing the directivity.
Not normally Horizontal as that is dictated much more by the drivers and cabinet or waveguide.Hi fluid, if by directivity you mean horizontal directivity, I think asymmetric slopes and delaying the lower drivers,
reflect that complementary acoustic summations cannot be achieved with the physical driver/speaker construction, and I think using those techniques gives the best/optimal compromise.
I prefer to rethink the physical design to achieve better acoustic complementary summations..
If you mean vertical directivity, or what I think of as lobe/beam steering...then yeah, but for only frequencies spanning xover ranges.
And I also wonder why any such steering is needed...why not just point/tilt speaker towards listener veristically on-ax,.... especially with home audio.
What are you thinkin ?
As to the main topic I really like Jriver and would not be without it in my own setup. I use the Jremote2 app on Android as a remote control. You can use it to control playback/volume, scroll through your music etc. One of the best things Jriver does is good volume levelling so there is rarely any need to change the volume between tracks and albums other than you want to turn it up or down for pleasure.
The MiniDSP flex 8 is probably the simplest solution, as setting up an active crossover through Jriver is not for everyone. The 4x10 was one of the first MiniDSP products and they seem to have upped their game quite a lot since then, so I would have less concerns about the reliability of it. There is really very few options in the hardware DSP arena.
As to the single ended outputs, just make yourself some psuedo balanced cables. Tom has a page describing it
https://neurochrome.com/pages/pseudo-differential-cable
Vertical directivity is what I mean as it can have a significant part to play in the overall DI of a speaker. When there is vertical separation there will be lobes/nulls, and yes asymmetry and delay can steer them to more favourable positions.
Tilting a speaker does much more than put the listener in the main lobe, it changes the phase relationship between drivers and alters the reflection pattern, it might be a good choice or not.
Even tilting the speakers response down will stop the crossovers from being completely complementary.
If you mean electrically complementary, 100% agree.I was mainly trying to point out that it is not incorrect to have crossovers that are not complementary, there are valid reasons to pick that compromise.
I dunno, why bother with that... I say ditch unbalanced gear, unless situation begs.As to the single ended outputs, just make yourself some psuedo balanced cables. Tom has a page describing it
That doesn't surprise me, but as it's clear we are not really discussing the same thing it doesn't matter. Trying to change your mind requires way too much time and effort. I'm not trying to be rude just pragmatic.If you mean acoustically complementary, 100% disagree.
Jriver has access to VST plugins, so if there is a plugin that can do the processing so can Jriver, when combined with Metaplugin there really is not anything currently available that cannot be done. There is also stuff like BEQ designer that was mentioned above.I can see it being a near perfect app for convolution processing, but don't see it worth pursuing to work with tradition IIR processing and delays, etc. Too rudimentary last I saw.
Has it the processing grown up since i last looked? (i'm within a year current version but haven't looked at its processing)
Becuase it is simple and provides most of the benefits of a fully balanced line. The important part is the differential input to the amp. Most gear processes internally single ended with conversions up and down anyway.I dunno, why bother with that... I say ditch unbalanced gear, unless situation begs.
The measured performane of the Flex 8 is a real step up from the 4x10, I personally quite like ESS DAC's. I'm not sure what you mean by encoder but the Flex 8 is quite different, using a SHARC DSP and XMOS control chip. The internal images have the mainboard look much simpler and more straight forward. Reliability is hard to quantify, very few devices seem built to last anymore. There really is almost nothing in this market segment between MiniDSP and professional solutions like Q-SYS.The Flex Eight may be the simple solution. It's performance may be an improvement over the 4x10HD and the smaller size is a bonus, but the company declined to tell me whether it used the same encoder as the 4x10.
The encoder is the volume control, source selector, and preset selector. The encoder on my 4x10HD failed multiple times.The measured performane of the Flex 8 is a real step up from the 4x10, I personally quite like ESS DAC's. I'm not sure what you mean by encoder but the Flex 8 is quite different, using a SHARC DSP and XMOS control chip. The internal images have the mainboard look much simpler and more straight forward. Reliability is hard to quantify, very few devices seem built to last anymore. There really is almost nothing in this market segment between MiniDSP and professional solutions like Q-SYS.
The newer units have IR remote control so there would be no need to use the encoder if you don't want to.The encoder is the volume control, source selector, and preset selector. The encoder on my 4x10HD failed multiple times.
It’s this one:The newer units have IR remote control so there would be no need to use the encoder if you don't want to.
The only other non PC option that I know of is the t.racks processors from Thomann in Germany. They deliver all over the world and shipping is usually quite reasonable. I know somone who has the FIR version and quite likes it.
https://www.thomann.de/gb/the_t.racks_dsp_408.htm#bewertung
Where does that value come from?Only about 86 SINAD though, so not super Hifi.
Me tooFor the money, I’d go with the Flex 8.
Their datasheet, the one I linked.Where does that value come from?
OK you converted the 0.005% THD to -86dB. I thought maybe there was a test I missed. This is pretty standard for previous generation audio interfaces. The Q-SYS Core 110f is 0.003% -90dB. Good enough to not sound bad but the newer generation interfaces and DSP's have moved this up a couple of notches.Their datasheet, the one I linked.
That’s the problem: he doesn’t have a digital solutionplug it back into your digital solution.
Fair enough.That doesn't surprise me, but as it's clear we are not really discussing the same thing it doesn't matter. Trying to change your mind requires way too much time and effort. I'm not trying to be rude just pragmatic.
Thanks, makes sense about anything is possible with VSTsJriver has access to VST plugins, so if there is a plugin that can do the processing so can Jriver, when combined with Metaplugin there really is not anything currently available that cannot be done. There is also stuff like BEQ designer that was mentioned above.
My big reason for balanced is I never get hum or noise problems with it....where as I occasionally have problems with unbalanced.Becuase it is simple and provides most of the benefits of a fully balanced line. The important part is the differential input to the amp. Most gear processes internally single ended with conversions up and down anyway.
I'm so convinced speakers, room, speaker processing in terms of how well executed, and source material ..........It’s this one:
Only about 86 SINAD though, so not super Hifi. For the money, I’d go with the Flex 8.
Well, yes, probably it’s going to be inaudible as long as SNR is plenty (which in this case, it seems to be). Still, I’d like to have THD+N around 100 dB at least. Besides, the flex 8 is only marginally more expensive, so why not go for it.I'm so convinced speakers, room, speaker processing in terms of how well executed, and source material ..........
each of which so vastly swamp SINAD...... and then put all together, yikes.........well, I literally never look at SINAD.
I guess I'm just a low-fi dude !
