Qudelix 5k/ldac transmitter and coreelec
unibomber
Hey,
I have a Qudelix 5k attached to some iems to watch movies on my coreelec android box. Coreelec only uses SBC Bluetooth codec and it sounds awful. Is there a usb bt that does ldac or a DAC that I can connect to my android box with usb that transmits ldac to my Qudelix?
Thanks
you can just run usb cable to the qudelix and use as usb dac, so its in best SQ mode. If you absolutely have to transfer wirelessly, it needs BT transmitter/Transceiver like fiio bta30pro, more expense for nothing.
There's also the fiio bt11 after doing some research. I need the Qudelix attached to my iems
