Any way to configure the PEQ without the phone app?
Nope.
Sonically I'm not worried. I'm sure the DAC is as good as or better than HeadRoom's ca. 2006 implementation.
https://www.stereophile.com/content/headroom-desktop-da-headphone-amplifier-measurements
I'm far more concerned with practical issues. Will the battery management support an always-plugged-in use case, for example?
Thanks. Feared as much.
Buy a $30 LG Rebel TracFone and you can use it via USB as a streaming Qudelix front end, while simultaneously using BT to control it via App.Thanks. Feared as much.
Depends on your definition - LineageOS with no GApps, and whichever linux distro I'm playing with on a PinePhone. I'm hoping the PinePhone software advances enough that I can ditch the LineageOS one, in which case I'd be limited to trying to get the Android app to run in Anbox. I really don't want to have to keep a separate phone just to control a headphone adapter! Plus if it's already connected to my desktop or laptop I'd rather do the adjustments from there than have to dig out a phone to do it. If there's some interface documentation around I can probably write the necessary app myself.Don't you have a smartphone?
Thanks - but why is that (and the DFU for that matter) hosted on Google Drive (or dropbox for some of the other DFU versions) instead of being available on their web site? Having a Windows-only DFU tool because of unreliable updates via bluetooth is a bit disconcerting too (found while having a look round the forum). I'll give the APK a try anyway.There's a direct link to the latest app APK on the Qudelix forum here.
Not that I’m aware of.If there's some interface documentation around I can probably write the necessary app myself.
I've done similar for the Forte's controls over USB where I had the Gen 1 Scarlett kernel support as a cheatsheet for a subset of it, so I'd be much happier with documentation!Not that I’m aware of.
Out of curiosity, I captured today a Bluetooth BLE protocol trace (Android phone <-> qudelix) while just changing from a previously saved EQ preset to another one and changing the volume. > 240 frames, mostly L2CAP / RFCOMM. Not easy (for me) to follow.
Does your HeadRoom amp have a balanced input? If not, then you can't use the Qudelix balanced output with it.Given that my primary intended use is as a fixed USB DAC/EQ feeding the HeadRoom amp, would a "balanced" 2.5mm TRRS to RCA cable be useful here?
Have you tested that with a multimeter?I don't think I'm getting the same levels as Amir did
In the Qudelix app, try the high power mode setting and see if it helps.
Yes, from this point of view, there is hardly any advantage.I have a hard time seeing how “balanced” is a real thing in headphones.
Balanced mode:
Works with Dual ES9218p
- Max. 4V RMS output
- 4-Wire Output from Source Device
- 4ch DAC/AMP required for Stereo Audio
- 2x more power and driving capability
But on top of that, many dongle headphone amps can effectively double the output power (by dedicating independent output channels to L & R) when in "balanced" mode.
EDIT: In other words, it’s not because the signal is balanced: It’s because L & R channels are driven by independent amp stages (dual mono amp)
Hmmm. Not really sure. I know that a balanced (2.5mm TRRS) connector is automatically detected in the app. But with a balanced to RCA adapter you are definitely shorting both (-) ends. Sorry, I can’t test that until Tuesday.So a “balanced” to stereo RCA adapter may help with output levels here?
