- Thread Starter
- #261
Exactly. Some of the music I tested, I didn't hear distortion up to 100%First off, I would like to ask ASR members to not attack the OP for his inexperience or not knowing what he wants. That is NORMAL for anybody new to this hobby.
Not a dealbreaker. You will likely get sound that you will be happy with, if your requirements are only that it will play loud. But you will not be getting performance that you have paid good money for, which is why so many of us are against the idea. The reasons why have been elaborated many times in this thread, so I will not rehash.
What you say is true. My gf came down last night to listen to music with me, and she listens to the cacophony that they call K-pop (Korean pop music). She listened to some of my classical pieces after my latest improvements to my DSP tuning, and she said "wow it sounds so real!". Then she wanted to listen to her K-pop and she was immediately disappointed. She complained that the singers don't seem to be in front of her any more and it doesn't sound real. I also pointed out a lot of things that are missing - like, no sense that it was recorded in a room, all the voices sound artificial, and that she had to turn the volume a lot lower to get the same SPL (because of the loudness wars). And I don't know if it would be even possible to hear distortion in heavy metal even if there was 100% distortion because it already sounds so distorted to me anyway. We listen to real instruments and if something is off with the tonality or timbre, it is much easier to hear because we know what instruments are supposed to sound like.
I can see some useful applications here. For example, if I'm doing something else while playing music in the background, this could come in handy. I had heard about ReplayGain, but I thought that modifies your original files, so I didn't mess with it. Would be curious if such loudness normalization can be applied non-destructively, on the fly.If you have a system that has an even frequency response and follows the ISO226 equal loudness curve, you do not need to crank it up. I listen at 75dB with ISO226 compensation* applied, and it sounds great. I find most people boost the volume because they intuitively know that the freq response is off at low volumes, or because their systems produce a lumpy freq response so they have to up the volume to hear what they want to hear. It might also be your preference to listen loud.
* this refers to how the freq response sensitivity of your ears changes with volume. Lower volumes need more bass and treble to sound the same volume.
It's possible that for shorter listening sessions BWs work better, but I did read that higher treble can cause fatigue. In general, I like treble, but can't tell if it has been my way to compensate for poor quality speakers.I am delighted that you got to experience that! For us, it's like telling you how delicious a burger is but there is no way to know until you actually eat a burger (I am one of those strange types who gets emotional about food!).
Revels are tuned differently to B&W's. B&W's typically have too much treble, which I am not a fan of. Revels have much more neutral tuning. But B&W's might work for you. I think you have also realized that what works in a small room will not work in a larger room. From what I remember, your room isn't that large. It's a bit smaller than mine, and I can tell you that I can put bookshelf speakers in my room and it's plenty loud for me. But remember my preference for volume seems to be much lower than yours.
Hahaha, it never ends!! Wait till you buy these speakers and start enjoying them. Then you get invited to someone's house with an amazing sound system. Then you will feel as if you have been missing out again. I have been in this hobby for 30 years, which is less than a lot of people on ASR. I have listened to dozens of systems in shops, hifi shows, and in homes. I still come across things I have never heard before and I am still learning.
For now, you should forget about subs, DSP, and so on. You might eventually need them, but right now you don't need them. Keep it simple and get the best speakers you can. The above advice should be taken an upgrade pathway, rather than something you need to do immediately. The most important rule for upgrading is: never spend money unless you have identified a problem and have a rational solution to fix it. You don't have speakers, so you don't know if you have a problem yet. What WE consider to be potential problems may not be a problem for YOU when you get your speakers and put them in your room. You might be perfectly happy with the sound, so you may not even need to go down this route.
BTW, it is hard for dogs to knock over a sturdy stand for bookshelf speakers, especially if it is very heavy. Some stands are hollow and you can take the top off and fill it with sand or lead shot (I found a 10kg bag of lead shot online for USD$50 ... I just looked). Some bookshelf speakers have holes so they can be bolted to stands. Of course, it depends on how big your dogs are. You could place some obstacles around your speaker stands so they can't run fast near them. And you can train your dogs not to run around in the house. I trained my dog not to walk on any carpeted areas. Just a thought.
My dogs are relatively big and one of them is a Malinois. He wouldn't do it on purpose, just an accidental knock. Plus I like to roughhouse with him, sometimes with some well timed music in the background. Few months ago, we knocked off the TV during play and the entire screen shattered on the inside. To add insult to injury, when I took it to a recycling place, I had to pay another $15 for them to accept it because of the punctured screen. Definitely reasons to worry for the speakers.
If I get the KH-150s, they include simple, metallic stands that are adjustable, which I like since I could play around with the height. But I agree, stands that can take in sand would be sturdier.
