Not sure if you're joking, but in my experience it depends almost entirely on the recording. Some have very little spaciousness.I found out I don't like huge soundstage as it sounds unnatural
sometimes a more focused soundstage is better
A true point source is a microphone in reverse. (one microphone). The point source argument is for manufacturers and owners of small speakers; they also use the lobing affect argument to try to convince others that their design theory is correct and others are not.A speaker thats not a point source, ie a twoway or threeway speaker is having a bit of ” sameness” on every recording regarding the size of the soundstage , which will show less differences than possible , compared to a true point source .
I met a couple of people with that opinion. Strange folks.
Nothing to do with Youtube but the recording method.You're judging from a YouTube video? I hope we don't have to explain the many problems doing that.
I think we're saying the same thing in different ways. No recording is going to sound like the speaker in your room.Nothing to do with Youtube but the recording method.
Your speakers are just about 50% or the sound you hear. The rest is the environment. In order to access a system with reasonable accuracy is to capture the sound waves reaching the ears. You need to capture the the acoustics environment. It got nothing to do with YouTube except at the extremities.I think we're saying the same thing in different ways. No recording is going to sound like the speaker in your room.
A very good judge of sound quality is to listen to good live recordings with applause and compare it with the real thing in the concert hall . A good single driver speaker outperforms all multiway speakers in such a test . Im convinced that the biggest fault in most loudspeakers are not the drivers or the cabinets, but the crossover thats never 100% transparent . This is very logical .I think that applause from a large audience, with the fast transient nature of sounds that will create, will maybe cause a lot of natural phase cancelations making the overall sound diffuse in a way that makes it hard to pinpoint. It can sound as if it comes from all around you.
Can you give examples of good single driver speakers?A very good judge of sound quality is to listen to good live recordings with applause and compare it with the real thing in the concert hall . A good single driver speaker outperforms all multiway speakers in such a test . Im convinced that the biggest fault in most loudspeakers are not the drivers or the cabinets, but the crossover thats never 100% transparent . This is very logical .
No loudspeaker driver can reproduce information thats already been lost in the crossover .
The sibelius loudspeaker is one great example . As all single loudspeaker it dont measure perfect regarding directivity or frequency linearity but take a listen to it - you will be surprised. This speaker made me sell my SAM monitors and build a clone. The soundstage is very big in all dimensions and at the same time razor sharp with very clear and pinpoint placement of acoustic instruments sounding very natural. It also does rock music well.Can you give examples of good single driver speakers?
The crossover can also compensate for the driver deficiencies, no driver is perfect, I have used that particular Mark Audio driver, too many compromises very poor performance even at moderate SPL, works pretty good as a head set.A very good judge of sound quality is to listen to good live recordings with applause and compare it with the real thing in the concert hall . A good single driver speaker outperforms all multiway speakers in such a test . Im convinced that the biggest fault in most loudspeakers are not the drivers or the cabinets, but the crossover thats never 100% transparent . This is very logical .
I have thought about why I like my current speakers so much and why they sound so natural, and one idea I have is that the midrange driver is doing some heavy lifting of playing the wide range from 380 Hz all the way up to 3500 Hz, and I think this works in almost a similar way as single driver speakers, at least for most of the "critical range" for our hearing of the frequency range. Just a thought, but the ATC midrange driver is golden and I will probably never look over my shoulder again.A very good judge of sound quality is to listen to good live recordings with applause and compare it with the real thing in the concert hall . A good single driver speaker outperforms all multiway speakers in such a test . Im convinced that the biggest fault in most loudspeakers are not the drivers or the cabinets, but the crossover thats never 100% transparent . This is very logical .
"What is disturbed by the crossover" may be the correct question.What is "lost" in the crossover?
Energy ( power ) is lost, perfect phase is lost, the direct connection to the driver is lost ( last thing important below emf frequencies, ie bass ). There are also things added from the crossover like delayed energy and distortion. A coil is one of the worst behaving electronic component .What is "lost" in the crossover?
