Might want to try the search tool. This discussion had been had multiple timesJust bought a Hypex ncore based amp and given these are direct ac coupled, I was wondering whether the amp would benefit from a power conditioner/ noise filter. What is the general practice here?
What do you mean by this?given these are direct ac coupled,
Not enough to be worth it.I was wondering whether the amp would benefit from a power conditioner/ noise filter. What is the general practice here?
I agree, I add a Corcom line filter when I build a class D amp, from an abundance of caution about line RFI/EMI.What do you mean by this?
But some common mode filtering is good practice to reduce EMI from switching powersupplys and Class Ds
Just get any old power strip, and don’t waste any money on power cables. The ones that came with your equipment are fine. Do you need surge protection? Most EU countries have decent power delivery… but if you want it, surely it can be had for way less than a Supra strip. But if you like the looks, go for it!I got a good deal opportunity for the used Adept Response aR6 unit for €1200, so I like the idea since I can get six power sockets with some filtering and power surge protection. Do you recommend to take the used unit or to get a quality power strip, for example Supra along with some quality power cord for devices?
Good luck finding a European power strip with UL…Only use products that have a safety sticker, like 'UL' but not 'CE'.
Why would you want to spend at least € 2850 for something that your amp should have solved in the first place?I´ve just noticed this video:
Anyone experience with the Audes PowerConditioners?
Have you seen the whole video? It´s not all about power conditioner - he goes through everal steps, starting with electrical installtion, then powersupplies, then filter then cable (he´s also mentioning that there are many filters which are nonsense, e.g. not filtering below 50Hz and over 800hz, something that - as I understood - was also critized from amir, point 1 at conclusions https://www.audiosciencereview.com/...evo3-aquarius-power-conditioner-review.30223/). Hence the video makes a kind of more balanced impression for me instead of onesighted voodoadvertisement - something may not be necessary (I´ve not enough knowledge of it), but a harsh "everything nonsense" sounds kind of imbalanced to me, as there are no further arguments. Ah and there is no need for 2.850€, he mentions also cheaper options: https://audio-freak.de/marken-empfehlungen/ifi-active-power-conditioner-netzleiste/ (749€), combined with dc blocker (149€).Why would you want to spend at least € 2850 for something that your amp should have solved in the first place?
That video is a load of nonsense, don't watch it!
Sadly, yes..Have you seen the whole video?
Sorry, just no. If you shill for an audiophile fuse, you lost the plot...Hence the video makes a kind of more balanced impression for me instead of onesighted voodoadvertisement
A broken clock is also right twice a day.something may not be necessary (I´ve not enough knowledge of it), but a harsh "everything nonsense" sounds kind of imbalanced to me, as there are no further arguments.
That's a totally different product, it doesn't even do the same thing, certainly not filtering from 800 Hz on. He also claims all kinds of nonsense improvements:Ah and there is no need for 2.850€, he mentions also cheaper options: https://audio-freak.de/marken-empfehlungen/ifi-active-power-conditioner-netzleiste/ (749€), combined with dc blocker (149€).
- Mehr Durchhörbarkeit und Separation
- Schwärzerer Hintergrund
- Verbesserte Feindynamik und Auflösung
- Weniger Schärfe, v. a. in den Höhen
- Und natürlich weniger Brumm, wenn man ein Gerät an der Erdungsbuchse der Netzleiste anschließt und eine fehlende Erdung der Grund dafür war
Snake oil pressed in Germany?Sadly, yes..
