Polk Signature Elite ES20 Review (Bookshelf Speaker)
Rate this speaker:
    Votes: 8 2.4%
    Votes: 38 11.6%
    Votes: 186 56.7%
    Votes: 96 29.3%
Very neat offering, I think this one's a success. Good to hear user reports on Polk's customer service being exemplary as well.
@pierre is this on your site? I couldn't find it. (Apologies if I missed it, or if you have been otherwise busy.)
I think this speaker is awesome but why does an JBL 305p for example have a higher score besides costing less? What am I missing?
Also @amirm a review of the top of the class ES60 would be interesting seeing how good this one is :)
Bass extension, I'm assuming.
I hate to beat a dead horse any more than the poor horse has already been beaten, but I think he can handle one more whack. This is the speaker that kills the GR Research Little giant killer speaker pair for $1000. The Polks literally blow them away. Price, bang for the buck, Amirs great testimony on lots of bass in a small speaker, what is there not to like at this price? Add in an inexpensive SVS PB1000 sub and you are all set for people shopping in this price range. These and a few other speakers Amir has tested smoke high priced goofy stuff like the LGK speakers. Just sayin........great Polk product for the price.
I wonder if there would be extra shipping fees to U.K. thanks to brexit - but don’t get me started on that subject!
How do they sound compared to the ELAC Debut 6.2?
I recently purchased the ELAC and they sound extremly harsh/bright to my ears. Especially movie or TV Dialog is almost painful. My only way to "fix" it was to set Treble to -2dB on my AVR but that makes everything slightly muffled.
Anyone using these as desktop PC speakers? I upgraded to the big ES60 and dont know if i should sell the ES20s or use them with an SMSL AO200 or similar.
They are a bit big but if you can fit them, they should be great as a desktop system. I would probably prefer the ES15 size-wise which still has enough extension to get away without a sub.
I really like this line from Polk. It errs on a little brightness but I don't find the excess to be objectionable in my room
This is a review and detailed measurements of the Polk Signature Elite ES20 bookshelf speaker. I purchased it from Amazon for US $349 a pair including shipping.
I really like the look and finish of this series from Polk. Despite budget pricing, it looks nice and purposeful as you can tell from the unique rear port plate:
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the tweeter center. No grill was used. Measurement temperature was about 62 degrees F (17 degrees C).
Polk ES20 Measurements
Let's start with our usual "spinorama" graph:
On axis is reasonably good, marred by some resonances between 600 and 1000 Hz. And some unevenness in high treble area. There is a directivity dip around 4 kHz.
I forgot to note on the graph the deep bass extension. F10 is at nearly 35 Hz! This is partly due to a cabinet that is deeper than normal.
We see the cause of that roughness around 600 Hz in our near-field measurements:
We see more of a dip in directivity caused in vertical axis mostly:
Fortunately my listening room has a thick carpet and high ceilings so I will be hearing a more optimal off-axis response than averaged above.
Predicted in-room response with my custom trend line is thus:
I usually draw the trend line after my listening tests are completed and do in a manner that is consistent with that experience. See the next section.
I was impressed by the smooth and constant horizontal beam width and dispersion:
This also has wider than usual response which should create a more diffused field around the speaker (my preference).
Vertically we have the usual restrictions but again, the sweet spot is larger than I normally see in this class:
I like the low distortion especially at 86 dBSPL:
But notice how that resonance around 600 Hz is also showing up here in the form of distortion. This means that we will have impact beyond that frequency due to harmonics.
We see the same resonance in impedance graph and waterfall:
Finally for fans of timing tests, here are the impulse and step response:
Polk ES20 Listening Tests
My female starting track which lacks bass sounding a bit muddy/tubby and somewhat bright. So I brought out the EQ tool:
First filter was around 600 Hz. It is a small filter but per past experience, it not only removed a bit of muddiness but also reduced distortion. The latter caused the sound to be more open and clear. Once there, on tracks with good bass, the sound was more or less balanced. But with female tracks without such, it sounded too bright to me. A quick and dirty shelving filter fixed that nicely.
Once there, I was extremely impressed with the fidelity. Track after track sounded beautiful. Not only was the tonality right but there was this clarity and lack of distortion that kept impressing me. ES20 could play pretty loud and distorted gracefully in that the woofer just lost deep bass and became a tubby. Pull back a bit and you were golden.
I can see Polk having to both want to create an accurate speaker while working within strict budget and retain channel that demands "showroom sound." To that end, they have done a very good job here, producing bass response that is way above what you expect. And do so with very little distortion. The only issue is the port/cabinet resonance which makes the sound muddy and screws up upper bass a bit. And elevated treble which can be a bit much if bass response is not there. Fortunately both of these factors are excess output meaning EQ not only fixes them, but also reduces distortion. Result is a speaker and sound that you can really be proud of.
I can recommend the Polk Signature Elite ES20 as is but hugely so with equalization. You are getting so much performance for so little money.
Thanks for the review as well as the note on EQ. I found it just the same as on my setup. (Plus -3db on around 60 Hz. But it was just my room condition). I put the speakers very close to the proximity walls and found that removing the rear port grilles help with the boominess.
I have the ES20 and I did some comparisons with some speakers I have and this Polk line provide great 'bang for buck', but possible a little big for a desktop setup. I have them setup without Subs in one room and it's very impressive. But because I liked these I also recently bought the much smaller ES10 and have them setup with a sub in my desktop setup. I believe the ES10 have exactly the same tweaker and to my ears have a similar brightness (which need a little eq) but that setup worked better for me in my small desk area.
That will naturally change the port tuning, for what its worth. The conical taper at the end makes up a portion of the port. Id imagine that it probably tilts the lower portion of bass response down a bit, but it could cause a peak higher up as the port tuning is now at a higher frequency without the rear plate.
I have the '55 floor speakers, and as far as I can tell the entire line is modular using the same 1" tweeter and overall design. The deviation is from the woofer beginning to beam a bit before the tweeter starts to take over, which causes the width of the response pattern to narrow a bit in the cross-over region. The nice thing about the bigger versions of the series with 6" woofer(s) is that instead of a "brightness", you can instead look at it as a shortfall in the cross-over region, which is pretty much at 2 kHz, which the shape and location coincides with the response of most simple graphic equalizers. A little infill at 2 kHz nicely fills it in and flattens out the in-room response. The same may be possible with the ES10 as Id imagine that same dip is probably around 4 kHz with the smaller woofer, but they may have a different response.
Quick question!
My NAD M10 V2 with Dirac Live recommends 80Hz crossover, which my SVS 300 Micro sub could achieve for my small office / computer desk but I am not sure if these ES20 are good enough for 80Hz crossover?
Since I can’t find anything else in this price range, if I have to set crossover higher on these ES20, it would suck to have to suffer with localization, which I am sensitive to.
Any advice?
Quick question!
Any advice?
I would definitely use 80Hz with these. Shouldn't be a problem at all
Quick question!
Any advice?
Hi.
Wow NAD M10 V2 with the Polks?
In my testing the SE20 is capable of significant output in a small space without fear of overdriving the speakers down to about 40-50hrz. (this is without any frequency boosting)
In a small room I would use a 40-50hrz High Pass with them.
I am not sure there will be any gains by tweaking that variable much unless you plan to hit 110db @the desk.
In a larger room, in the farfield, and for loud playback 80 hrz sounds reasonable or even 90hrz. But still even in a large room for 85db average(fairly loud) playback levels the SE20 can get by with a 50hrz X-over(but I would choose 80 only as I prefer higher crossover points and use multiple subs). Above 85 averages(very loud) then 80/90hrz comes right into play.
In any case in a small office at a desk you will surely never drive them that hard.
The real issue is measuring to make sure you are getting a good blend with the sub as that can be hard especially at a desk. I suppose Dirac will help you.
Are we talking about a 3k€ amp and a 1k€ sub, that your plan to pair with some 200€ speakers...? Why ?
I know, little correlation between price and performance, but, hell !
I now, little correlation between price and performance, but, hell !
Yes, ideally I would get a better pair of speakers for the NAD M10 V2 but since I already blew my budget on the 3k+ amp, I think these Polk ES20 is the best value money can buy in this price range, until I have funds to upgrade to better speakers in the future. Actually I am thinking if I can get away with the even cheaper ES15 or ES10? Any thoughts?
In a larger room, in the farfield, and for loud playback 80 hrz sounds reasonable or even 90hrz. But still even in a large room for 85db average(fairly loud) playback levels the SE20 can get by with a 50hrz X-over(but I would choose 80 only as I prefer higher crossover points and use multiple subs). Above 85 averages(very loud) then 80/90hrz comes right into play. In any case in a small office at a desk you will surely never drive them that hard.
@warpdrive @ROOSKIE thanks for confirming that 80Hz crossover wouldn't be a problem.
@ROOSKIE yes I am counting on Dirac to help with integration but choosing the crossover seems to be still up to the user. I am mainly just concerned with localization.
