Polk Signature Elite ES20 Review (Bookshelf Speaker)
Rate this speaker:
    Votes: 7 2.4%
    Votes: 38 12.9%
    Votes: 168 56.9%
    Votes: 82 27.8%
thanks!! I want to now if the SE worth the 180usd difference.
Amir reviewed the smaller Polk 'S15' and the Polk 'ES20'
based on these reviews, I would buy the Polk ES20 instead of the S20
This is a review and detailed measurements of the Polk Signature Elite ES20 bookshelf speaker. I purchased it from Amazon for US $349 a pair including shipping.
I really like the look and finish of this series from Polk. Despite budget pricing, it looks nice and purposeful as you can tell from the unique rear port plate:
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the tweeter center. No grill was used. Measurement temperature was about 62 degrees F (17 degrees C).
Polk ES20 Measurements
Let's start with our usual "spinorama" graph:
On axis is reasonably good, marred by some resonances between 600 and 1000 Hz. And some unevenness in high treble area. There is a directivity dip around 4 kHz.
I forgot to note on the graph the deep bass extension. F10 is at nearly 35 Hz! This is partly due to a cabinet that is deeper than normal.
We see the cause of that roughness around 600 Hz in our near-field measurements:
We see more of a dip in directivity caused in vertical axis mostly:
Fortunately my listening room has a thick carpet and high ceilings so I will be hearing a more optimal off-axis response than averaged above.
Predicted in-room response with my custom trend line is thus:
I usually draw the trend line after my listening tests are completed and do in a manner that is consistent with that experience. See the next section.
I was impressed by the smooth and constant horizontal beam width and dispersion:
This also has wider than usual response which should create a more diffused field around the speaker (my preference).
Vertically we have the usual restrictions but again, the sweet spot is larger than I normally see in this class:
I like the low distortion especially at 86 dBSPL:
But notice how that resonance around 600 Hz is also showing up here in the form of distortion. This means that we will have impact beyond that frequency due to harmonics.
We see the same resonance in impedance graph and waterfall:
Finally for fans of timing tests, here are the impulse and step response:
Polk ES20 Listening Tests
My female starting track which lacks bass sounding a bit muddy/tubby and somewhat bright. So I brought out the EQ tool:
First filter was around 600 Hz. It is a small filter but per past experience, it not only removed a bit of muddiness but also reduced distortion. The latter caused the sound to be more open and clear. Once there, on tracks with good bass, the sound was more or less balanced. But with female tracks without such, it sounded too bright to me. A quick and dirty shelving filter fixed that nicely.
Once there, I was extremely impressed with the fidelity. Track after track sounded beautiful. Not only was the tonality right but there was this clarity and lack of distortion that kept impressing me. ES20 could play pretty loud and distorted gracefully in that the woofer just lost deep bass and became a tubby. Pull back a bit and you were golden.
I can see Polk having to both want to create an accurate speaker while working within strict budget and retain channel that demands "showroom sound." To that end, they have done a very good job here, producing bass response that is way above what you expect. And do so with very little distortion. The only issue is the port/cabinet resonance which makes the sound muddy and screws up upper bass a bit. And elevated treble which can be a bit much if bass response is not there. Fortunately both of these factors are excess output meaning EQ not only fixes them, but also reduces distortion. Result is a speaker and sound that you can really be proud of.
I can recommend the Polk Signature Elite ES20 as is but hugely so with equalization. You are getting so much performance for so little money.
Hi Amir, thanks for the great review! I bought the speakers and happy with them so far! I am an absolute beginner when it comes to parametric EQ, but I have applied your suggested EQ in my WiiM amp app and the speakers sound better! They are still a bit bass-heavy, though, and boomy and my next door neighbour claims he can definitely hear the bass through our shared wall! Can you recommend a further parametric filter (in addition to the above) to make the bass less boomy but still retain some bass (which is the reason I bought these speakers for)? Thx so much!
You can typically reduce the boomy mid-bass by decreasing FR around 250HZ. Tweak the Q (wider or narrower) to your listening taste. Same with the PEQ center freq point. Possibly moving it down (but probably not up). This FR range depends on your room, so someone else giving you the precise numbers they use in their room would likely not be the correct parameters for you. Experimentation with placement, or even better, measurement with a microphone & software, may be necessary for the ideal optimization.
Bass freqs are the most prone to travel through walls...just the nature of physics.
Thx so much!! Given I am a newbie in this field, could you please explain how I action whet you said via the WiiM amp app settings? I can choose a filter type (LS, PK or HS), a frequency for this , a gain and a Q value by typing or increasing / decreasing values.
Much appreciated
You might try the (LS) low-shelf (ie bass) filter first. This will be easier if the PEQ tool allows you to visualize the curve.
If you or a friend has an iPhone, try measuring the in-room response using HouseCurve.
In the HouseCurve settings, set smoothing to Off to clearly see your bass peaks and dips.
You will most likely have one or two significant peaks in the bass response, which are frequencies of constructive interference.
Take note of the exact frequency and height in dB, and add a Peaking filter with matching frequency, but inverse dB in the WiiM App.
If you have a +11dB peak at 78Hz, add a 78Hz, -11dB Peaking filter in WiiM.
Play around with the Q value to best match the peak for a smooth response.
You can take consecutive measurements as you refine the EQ to help find the best settings.
You can also let HouseCurve calculate the ideal PEQ settings for you.
I wonder how the smaller Polk ES10 4" satellites perform? Considering them for a 2.1 desktop system
The ES20 go pretty low without a sub - with a sub you could go for the ES15 ( though that speaker hasn’t been measured here I imagine it’s similar but with less bass extension)
I have a pair of the es10 paired with a sub in a small desk setup but that is my simple setup with a aiyima d03 - it works very well for what it is and where it is but you have a much much more expensive amp and sub so I would not go as small as the es10.
The ES20 is a nice speaker ( a great bargain at €200 ) but possible even too big for a small desk / office setup.
I'm considering ES10 for desktop 2.1 system as well. Are these bright speakers? What did you cross yours over at with sub? I was thinking 100Hz
Accessories 4 Less dot com is currently showing inventory of 'refurbished' Polk Audio ES20 loudspeakers with a 2-year manufacturer warranty in Black, Walnut, and White for $249.00 a pair.
There are no measurement reviews for ES15,
can I assume that past reviews of the S15 are similar to the ES15?
Based on nearfield listening at my computer desk, the ES20 is too loud for me.
So, I'm keeping an eye on the ES15.
I bought ES15 based on the ASR ES20 review - I think ES15 are superb, not many 5.25" bookshelves can hit 44 hz on the low end and they are much easier to place. ES20's are big & deep with the same tweeter on both models. They also take well to EQ.
Got to respond in kind - I couldn't really see anything wrong with the crossover either - poly cap where necessary, air coils which I 'm sure are fine for the power handling, resistors the same and one electrolytic which again, should be fine for a ten plus year life and the extra resistance must be part of the crossover tuning?
Danny pushes this notion that, more expensive crossover parts, especially capacitors, tube connectors and so on, will almost "magically" make the sound better in some way that he can never truly quantify, or explain, nor can be measured. He simply says it makes the "Sound" of the speaker and how "Good" it sounds....
All the measurements do is show how accurate it is, according to him.
His golden standard is to simply trust him and try/buy his (expensive)"kit" and it has to sound better.
The thing that gets me, is he will not Sell just the schematic for his "revised/improved" crossover, but ONLY can be had by purchasing the expensive upgrade, with ALL parts included. Leading me to believe, quite obviously he has a mark up on the parts, and for sure the "tube connectors" and "No-Rez"
We're kind of distant from all that over here, but I agree that selling the entire kit gives him a healthy markup and the tube connectors something 'different' for him to peddle to the faithful. No wonder he fell out with Amir when he was challenged on one or two areas.
We barely see many of the US-popular raw products here, such is the UK lower cost market now all but taken over by a healthy used gear side (but less engineers advertising reasonable rates to repair and restore the gear sadly and the few around wanting the thick end of a hundred quid just to place it on the bench - overheads be damned... but I'm digressing again with apologies).
I'm listening to ES20's that replaced Elac DB6.2's. They are fed by Spotify>WimPro>SMSL D-6S>Fosi ZA3 (with the 48V power suppy). No sub with them (haven't felt the need to hook it up with them yet.).
As mentioned, the bass from these is really good and something I didn't really expect. These surprised me in a good way.
Sound is excellent overall. (Better than the Elac's IMO and they are now gone.)
I haven't played with the eq values mentioned...yet. Also not sure if there is a break-in time frame for these. Has anyone noticed any changes after some hours?
The only thing I keep thinking of is if I should have went for the R200's and if they will bring much of an audible improvement or just less in the bank?
Some of the test tracks I like to use ...among many others...are: Cool Cat -Queen, Walk this land -EZ Rollers, Night Time -The XX, River - Natalie Merchant, Sky Blue Sky -Wilco (Wilco's recording sounds especially good to me on Spotify for some reason.) Promise -Laufey, Billy Bossa Nova -Billy Eilish
I'm listening to ES20's that replaced Elac DB6.2's. They are fed by Spotify>WimPro>SMSL D6S>Fosi ZA3 (with the 48V power suppy). No sub with them (haven't felt the need to hook it up with them yet.).
Welcome to ASR,
Consider whether you can obtain the Polk R200 with return privileges - so as to compare to the Polk ES20. Regardless, consider using the WiiM Pro to deploy the Parametric EQ settings suggested for the Polk ES20 or the new Room Correction feature (if you can use the WiiM Home app for iOS) to see if you like the sound in your listening space.
Welcome to ASR,
Thanks!
I'll have to try the one in the app as I don't have iOS.
A pair of the previous generation (S20) that were kindly given to me by a Polk forum regular reside here. They're a bit "heavy" sounding, but overall quite acceptable. My only complaint about them (which is extremely minor) is that they're kind of large for my "ideal" application for 'em.
All this being said:
  1. It'd be interesting to compare them to the ES20.
  2. It'd be interesting to compare them to the ES15 (or S15 -- was there an "S15"?).
  3. It'd be interesting to compare them to the ES10.
Welcome to ASR,
I've been listening to the ES20's with Amir's EQ via the Wiim Pro for a while now. It's a a subtle but nice improvement. I'll keep them and hold off trying the R200's until I find a really good deal on them.
