- Thread Starter
- #41
In the end I was able to get good results by using the alignment tool to adjust subwoofer delay/distance:
As it happened, the additional delay/distance was -7.69ms/-2.636m for a crossover at 60hz. I got this figure by averaging the calculated figures for aligning the sub to left and to right at the crossover frequency (they were pretty close already, but not identical). Despite @terryforsythe's warnings about the phase transition, the 60hz crossover point just measured smoother than other options. Aligning the sub to the mains screwed up the center crossover a little, but that's just a tradeoff I guess. I just chose the least bad of available options.
Plugging the ports was definitely not a good idea with these speakers. Instead of just changing the slope of the rolloff at the bottom end of the speaker, it depressed the bass response by something like 3bd/octave starting around 150hz.
I'm satisfied for today. On another day I'll try to fix another problem. Like all that LBIR between 100 and 200 hz.
Thank you all for all your advice. It was a big help, and I appreciate it.
