Because the OP did not want to spend an arm and a leg... $60 for 2 meters of wire is preposterous coupled with a $350 amp.Why look at the low end?Others pay $2000
Cheap can be expensive if you blow things up.Because the OP did not want to spend an arm and a leg... $60 for 2 meters of wire is preposterous coupled with a $350 amp.
I thought we were on ASR, 60 gbp for 1 meter of assembled speaker cable? What the hell!That is what I would choose:
Loading…
www.amazon.co.uk
You can find cheaper but not nicer for a desk that flexibility is a must.
Those should work well. The key thing about attaching speaker cables is to maintain the same orientation (red/black) for both left and right sides. Both the WiiM Amp and your Revel speakers are color-coded to make this foolproof. Enjoy!Amazing, thank you kindly I've ordered them.
*pair,so 2 meters*I thought we were on ASR, 60 gbp for 1 meter of assembled speaker cable? What the hell!
Thank you for this, knowing me I would've plugged everything in and just flicked it on immediatelyYou are heading towards a nice system
Quick sense check: when you are connecting your Speakers to your Amp turn the Amp off first (unplug it). Easiest way to avoid any problems if you accidentally touch live cables. It's not dangerous to you, but it's not good for the equipment.
well... ASR have surely made audio gear shopping like thrift store hunt for many.....Never thought of ASR as the equivalent of a thrift store.
Mogamis are established nice pro cables,nothing to do with snake oil.
Anyone is free to choose what they want.well... ASR have surely made audio gear shopping like thrift store hunt for many.....
Many people aren't buying 3000$ amplifier anymore, replacing those with 300$ in search of audio fidelity or otherwise.
Mogami are very good for sure... but there are equally good cheaper alternatives... one can just apply the same logic as amplifier hunt!
Other go for cheap,others for performance,others for looks,etc.
In my recommendations I reflect myself,safety,ease,care free operation,headroom,looks and performance.
And I know it would be a boring world if we all liked the same stuff.
I stand corrected, I didn't read it properly and didn't notice they offered a pair of cables. 30 GBP each is much more reasonable. Especially when factoring in the cost for the time needed for getting the tools out and assembling your own banana plugs on the cable ends.*pair,so 2 meters*
My view: the Mogami is good cable and it ought to be well built. It is more expensive than is really necessary, but it's not stupidly expensive. Don't stress about this - especially since the OP has already bought it!
Fit it, forget it and enjoy the music
But it actually gets unnecessarily expensive when you look at a bit longer ones, but nice and durable for sure.
Yes, you can see the two types at either end of the cables I linked. Your speakers appear to be able to accept either. Assuming the banana end fit into the WiiM amp, I'd connect the other end to speakers via spades. It will also work in the opposite orientation: spade end at the WiiM, bananas at the speakers. Avoid the "pin" connector.
Pin - Spade - Banana
If you can get away with a slightly shorter cable, I also like these:
UCINNOVATE 2 Pack HiFi OFC Speaker Cable with Banana Plug to Jumper Spade, Banana Plug to U Fork Plug 14AWG Speaker Wire Cord Jumper Bridge Cable for Speaker Amplifier (6.56FT)
You're right (as you usually are), and I was going to recommend this myself, except that it's too easy for a newbie to cross-wire the speaker/amp connections and have serious phase-shift. But since he's dealing with what? one meter of wire? this shouldn't be a concern as long as he marks it on the cord.Why waste $60 on 2 meters of cable... you can have the same result for way less. Just get some decent copper lamp cord, at least 2.5mm^2. Just connect them bare wire, no need for silly connectors.
Okay so I bought the WiiM amp. Thanks a lot for that. How do I connect it to the speakers when it comes? For the 'purest' sound?
"upgraditis" ... it's a curseSo fine and the WiiM will probably work very well: got a decent review from Amir. However the Revel M206's "deserve" an even better amp and you'd do will to consider that for the future.
For a one-box solution at moderate price I personally would consider the miniDSP SHD Power. If I were able to go a bit nuts I'd look at the NAD M33.
