curiouspeter
Let's say you have audio files in DSD format, would you rather convert them to PCM and apply room correction, or would you rather play them as is, assuming a delta-sigma DAC with native DSD support is used?
Is this going to be unanimous? Is there someone who has actually made the comparison going to argue?
I'd rather correction. DSD is a scam anyway, everything is worked on in PCM because not a single DAW out there supports DSD.
DAWs still don't support DSD, and having recorded and mixed orchestras, I can say for a fact that's not really quite accurate.Some music (e.g. classical) does not need mixing or complex editing. Just have one mic per channel and record in DSD256. This way, it is possible for a recording to have stayed in DSD the whole time.
Okay, so the main problems with this are twofold:I thought the latest MOFI system uses DSD for the entire mastering chain? Up until 2016 or so they used to mix in very high rate PCM and then up-sample to DSD (I believe). Paul at PS Audio also talks a lot about the Sonoma recording and mastering system at their Octave record studio which is all in DSD. Of course these are smaller niche companies with targeted audiences. Not for mass market production.
The only downside to the Modius is you need an analog-side volume control. Otherwise, it's a well made solidly performing DAC. I don't consider 192KHz PCM to ever be a bad upper limit.I am just trying to decide if I should get a Modius (or shall I say Bifrost LOL) for my speaker amp or something like a DSD-capable D70s just to be sure.
1, studios suitable for recording classical are running Pro Tools HD almost exclusively. Pro Tools does not support DSD at any level, only PCM.
2, even DAWs that claim DSD support are transcoding it to high sample rate PCM for processing, and Sonoma is no exception (it's 2.822MHz 8 bit PCM, or as they call it, "DSD-WIDE"). More common is DXD (352.8KHz/24 bit PCM).
That's because it's impossible to do _any_ editing in DSD. Even a simple splice can't be done without causing a click.DAWs still don't support DSD
Some labels will perform a session analog mix and balance before A/D conversion, but most labels, perform that mix and balance digitally in post production. In any case, post production always includes editing to correct note or tempo phrasing, and playing errors.
Yes, but... why would you do it? There's literally no point. There is no technical benefit.Some music (e.g. classical) does not need mixing or complex editing. Just have one mic per channel and record in DSD256. This way, it is possible for a recording to have stayed in DSD the whole time.
