Strange DAP / DAC Foepoe UD951C - DSD Multichannel support?
AresLuna
This is my first post / thread in this forum.
I have been reading extensively many sections of this wonderful website and i am glad to be part of the community now.
I am interested in finding an affordable solution for a DAC or independent DAP that is capable of outputting multichannel audio through RCA unbalanced to my receiver for listening to my collection of SACDs and generally dsd multichannel audio. I know that most audiophile SACD players (if not all?) are two channel solutions and that most album releases are mainly in stereo, but there are some really important recordings or remastered re-releases of historical classical concerts that interest me. Those are a whole different experience when heard from a multi-channel setup.
This topic has been thoroughly discussed and so far there are only a few options available. For native DSD playback, an Okto DAC8 for example (need to convert balanced outputs to unbalanced RCA) or an exasound E38 + exasound PP (if someone wants it as a DAP, that also has an absolutely correct DSD gapless playback), but these are some extremely high quality and expensive solutions.
A more affordable solution is (or better was) the discontinued Topping DM7. I wish the company would release a similarly (or lower) priced version with RCA unbalanced outputs only, as it would fit my personal DAC needs for good considering DSD multichannel playback alone.
If someone doesn't mind converting to PCM, which means no pure DSD decoding there are very cheap solutions like the ESI Gigaport (which i know is a noisy device) or similar 6-8 channel solutions.
I found this interesting sale on Aliexpress of a device that is of questionable quality, both in terms of build quality and audio quality that it is able to give through its outputs.
What is more interesting is the video on the link. I don't know if i am allowed to post the link to the aliexpress sale, so i will only post the video link.
We can clearly see that this relatively inexpensive player is playing DSD files (both DSD64 and DSD128) in 5.1 as shown in the display. This player has 6 RCA multichannel unbalanced outputs and is able to play DSD files including ISOs and DSTs in both 2 channel and 5.1 channel configurations.
I have never seen this in another device of such low cost.
After my first excitement, i noticed that the chip used is the ES9023P PCM only dac. Which apparently means that there is a DSD --> PCM conversion that allows the player to output 5.1 channel audio playback from such high res audio files. (with possibly devastating audio degradation?)
I remember back in the days when most universal DVD players that could playback SACD discs would use the MT1389 MPEG IC that would decode DSD and convert it to a 88.2KHz 24bit PCM stream to feed a basic PCM dac chip with audible (and measurable) degradation.
It would be interesting to know what kind of conversion is going on in this chinese DAP as it would be interesting if that is higher than 88.2KHz 24 bit PCM.
Another variant that i have found is this one:
Although this one states clearly that it has a DSD capable ES9038PRO chip and an LME49720 opamp. Could this provide a pure dsd multichannel playback?
SACD players made nowadays are only high-end models from reputable makers, costing thousands of dollars. Still they are not able to offer multichannel DSD playback as the old universal players like the Denon DVD-2910 did.
So i am still looking for an affordable solution to this, as my Denon / Yamaha and little Samsung Universal DVD/-A/SACD players have started showing signs of age on their laser pickup assy's. Also a lot of my SACD original pressed discs have started showing signs of wear and i can hear tiny pauses during playback or even the player comes to a halt and requires power off and power on again.
If this performs well enough with an adequate dynamic range and low distortion, it could be a solution for multichannel DSD playback, even though it isn't a "pure DSD" one .
Does anyone have an experience with this player? How does it sound? Do we have any measurements that provide some scientific data on how it performs?
Do we know of any recent attempts or products that are similar to the Topping DM7 or anything that is based on a respectable dac chip and provides pure DSD ouput through RCA, a DAC or a DAP or both in one device?
It works for me, but i will post the original Aliexpress sale with the video.
This is NOT to advertise this or to recommend it as we don't know anything about the device.
My intention is for people to see the video and specs and to try understand if this is a solution worth checking or not.
And this is the PRO version with the DSD capable ES9038 chip.
What interests me are these two screenshots.
Take a look at the bottom of the display.
2024-07-18 13_24_11-gv-vod-cdn.aliexpress-media.com_80ffc57ef0293a3a_ae_sg_item_7FLg0Shw927hYQ...png
2024-07-18 13_25_01-gv-vod-cdn.aliexpress-media.com_80ffc57ef0293a3a_ae_sg_item_7FLg0Shw927hYQ...png
The 5.1CH label seems to stick on the display regardless the selected track, it may show the currently selected mode.
ES9023P is a stereo chip, it's rather unlikely they would put three of these inside. IMO the description is not correct.
But it has multichannel audio outputs. These should be connected to a dac chip somehow. So why not a triple ES9023P configuration?
Another similar device with the same config.
And another one:
And another one:
All these share the same firmware (or similar) as you can see from their screens.
Whether that 5.1 indicator on the bottom shows the currently selected mode or the last file format it was playing, it does not rule out the possibility that these devices could support playing multichannel dsd files from their RCA outputs.
Any ideas or comments on this? Maybe someone who has tried some of the above devices could shed some light?
Indeed, for the ES9023P version there is a DSD ---> PCM conversion for sure as i wrote in my first post. The thing is, how is this implemented? Is this just a usual 88.2KHz 24bit conversion which can be of inferior audio quality or a higher sampling conversion that could provide a pleasent listening experience?
As for the ES9038 version of the device, does this implement a pure dsd path from the decoder to the dac chip or does it still convert to PCM?
The biggest question of all is if these devices really can play multichannel dsd audio, no matter if it is a pure dsd or a conversion. And if it does, how well it does it.
just looking at the front plate and screen.... does this look like a device worth spending your money on
i think the funny this is that you will come across streaming media that have formats that are not support but this device
this company also has the 9038 version but the price gets very very high - i question do people in china even buy this stuff?
i know this has some 'free' surround formats that are pretty much worthless now but if you want streaming get a wiim ultra?
Thing is i want to listen to my collection of SACDs that i have bought with my savings during the last 20 years. Some of them have shown signs of wear and my SACD/Universal DVD players (their laser pickups are showing signs of age as the laser power needed adjustment which i did with my oscilloscope), they are skipping or even pausing completely. I managed to rip them to ISO files. So far i have about 130 physical discs and some more that i have downloaded. I have also bought some multichannel DSD files so i want to be able to listen to those too.
My main concern is MULTICHANNEL DSD audio playback, in "pure DSD" or via conversion to PCM (88.2 / 176.4 / 192KHz) as long as this conversion is done in a way that preserves most of the resolution and sonic qualities of the original DSD information.
I am not interested in streaming other formats. I am only interested in multichannel DSD and that is why i am trying to find a relatively affordable solution.
I agree that these devices don't have the good looks but never judge a book by its covers especially when it has to do with audio gear.
As a DAC i am using an SMSL D6S but this is only for 2.0 stereo listenings and does not cover my needs for multichannel audio.
As you realize, my physical disc players are not that reliable anymore and i can't stop my listening sessions due to disc reading problems and then resort to my SMSL DAC to listen to the recording only in stereo.
About 60% of my collection has stereo DSD recordings only, but the rest 40% which is multichannel is really very important to me.
Does anyone have any suggestions?
1. Get a PC.
2. Add Jriver
3. Find a used Topping DM7
Thank you Mr. Rubinson, your suggestion is what i am trying to accomplish.
I already have a PC and a good one, also a Jriver license.
BUT, i need a Topping DM7 as you correctly suggested!!!
I will be looking for a used DM7 from now on.
Or an Okto / exasound if i start saving some money! :)
Hello, I have been using an RH-899x as described further up this post.
I use a PC with HDMI out into the DAC And then the return HDMI into a monitor. There is a toslink from the TV box and various other peripherals. I have another PC with a pcm coax. Output primarily for redundancy. Left and right channels feeding into a QUAD 44 that has been extensively modernised And that feeds to QUAD 405RM that are vertically bi- amped . The Centre Channel is a home-made active speaker system. Using an extron Power amp converted to mono and surrounds by a lovely old Sony ta-ax2. This is further fed into another extron stereo power amp to boost the rears. Also, there is a lf bass speaker To control and balance all this I use four stereo volume controls Left and right front, Centre, rear surrounds and bass.
The mods to the quads mean there is silence during running; no hiss or hum. My main speakers are B&W matrix threes.
Using the PC / foobar2000 to play DSD iso files or multi channel Flac files I am more than impressed. The sound is nothing short of stupendous. The sound is crystal clear there is zero distortion it sounds warm luxurious involving very three dimensional. It is impossible to tell where the sound is actually coming from because the stage is so wide it is perfectly possible to place the instruments exactly as they are. It is so revealing, for example when listening to the song remains the same you can literally hear the floor where John Bonham drums are sitting on vibrating.
I have a large SD DSd collection and thoroughly enjoyed the immersive experience from these recordings. I have no one favourite but lots of Billy Cobham, war of the worlds, the Beatles Abbey Road The Moody Blues and jean Michelle jarre and tubular bells all explode with absolute incredible multichannel vitality. All from this little box the RH899X.. Even my brother who is critical said it would not sound better had you spent £20,000 on this system. The RH899X is very versatile, has many inputs. HDMI coax toslink analog so card usb etc. The remote controls the volume and the inputs. If it was trash, I would’ve canned it long ago. Occasionally I search for a more mainstream device which is how I found this forum and without spending thousands or making sacrifices on inputs yet to find anything. Realistically, there’s no reason to replace the RX899. Purists may it’s not pure DSD it’s dsd converted to pcm or whatever but I use my ears. I invite anyone to come and listen to what I’m hearing and criticise so for £150. This box does the job.
If this player were to support hdmi out to a receiver, this will be more practical imho. As for DAP the size of handphone or smaller, a mini hdmi out would be ideal to connect to a receiver (mini male hdmi to normal male hdmi cable needed) to support multichannel playback
This is great, I also am looking at this unit and needed more info on it, thanks to all posting here My situation is a little different, I’m running a denon avr -1802 (has 5.1 rca inputs) in my “secondary” Htr system (don’t ask how many I have it’s kinda ridiculous) but frustrated with no hdmi, using an extractor to toslink / pcm out but it’s clunky. I got a much newer Yamaha receiver but - omg - it sounded terrible! I was shocked and sickened by the lack of depth, presence and warmth. No way I’m giving my old denon up after that experience, but now searching for true 5.1 decoding to rca out - which this unit has, along with other convenient features like Bluetooth and usb inputs - perfect solution for me! But is it true 5.1, with Good enough audio quality? I’m encouraged so far, if I take the plunge I’ll report here (long delivery time from China though).
With the standard 30khz filter applied, 88.2khz is more than enough for DSD>PCM conversion.
BTW I’m running an onkyo PR-SC5508 in my “primary” htr (feeding hafler xl280 and adcom gfa-2535 into polk sda2 front, hts 50cf center and 8” pinnacle in walls f/ surround. I’ve been evolving this system since 1986!) and the denon has lately been acting up, the hdmi chip might be going. (Grrr - so much $$ for failed tech!) if the onkyo chip does fail, an rx899 could feed it as a passive multichannel preamp.
Question: will the rx899 control a usb hard drive or spinning disc drive? If so how much memory can it handle? It would be too sweet if this thing could be a one-stop streaming center
