I wonder if a Puffin is for my Stanton st150 and it's original cartridge
I'd probably get Art DJ Pre for that. Puffin is for versatility with lots of expensive carts, especially MC. Up to you though. The noise filter is pretty cool with old worn records.I wonder if a Puffin is for my Stanton st150 and it's original cartridge
Maybe Schiit Mani then.Yes, but I can't stand its design for sure
What I'm wondering is a Puffin worth its cost to play mostly recent recordings ?
Have you looked at Parasound Zphono USB ?Yes, but I can't stand its design for sure
@watchnerd dunno, it felt like the Puffin is more for playing old vinyl records from the attic
IME digitising the cartridge output then applying RIAA correction in software gives a quieter and more accurate output than an analogue phono stage.Ideally yes if you want make high quality no-compromise masters or one time digitize your collection then you want a high performing ADC and a great sounding standalone phono stage. The puffin has been getting rave reviews so if you can get over the looks then it would work out great. You dont have to look at it though.
But what is the point in a 24-bit recording of a medium with a DR of 11-bit at maximum?My only problem with the puffin would be the low dynamic range. Its ok even marginal for maybe 16-bit. But for making high-resolution copies (96khz 24bit) I dont think its up to the task. For that you do need a phono stage with a lot of dynamic range (see aamir's chart in the first post where puffin lands in this regard as compared to others). And, also, a adc with high enob (effective number of bits - no point in doing a 24bit recording if the phono stage or adc can barely resolve 14-16 bits).
I don’t think it’s that low across the whole spectrum. If you ever saw a fft spectrum of a quiet groove on a good turntable with a good stylus you will see that from midrange through high frequencies the dynamic range on a record is actually pretty good. Sure not as great as 24bit. It just gets badly dinged in the low (less than 200Hz) due to rumble and physical noise. Btw, the purpose of doing a high Rez copy is to avoid too much resampling in the master copy,
You can resample and compress to your hearts content for copies from the master.
I think it is that low over the best part of the spectrum. At higher frequencies it is not as much as 11-bit because of the problem of cutting high levels at high frequencies.I don’t think it’s that low across the whole spectrum.
