computer-audiophile
What about cogging?areas I can see the newer decks being objectively better are platter resonance and feet isolation, as well as power supply mechanical hum and EMI
It's worth noting that Technics destroyed the tooling for the orignal 1200/10 when they discontinued it around 2009/10.
My GR arrived today. Haven’t listened to it yet but I placed it next to my MK2 that I bought new in 2000. Visually the GR looks and feels better quality (mostly). That could all be superficial though and it’s not really a fair comparison between a brand new machine and one that is 22 years old. I’m not expecting any real audible differences but I’m certainly not disappointed with the purchase either.
That's exciting!
You are in a great position to make some real comparisons, take some measurements and tell us what your impressions are.
The only way to settled this is to record both TT and analyse the digital file the same way we would analyse any digital file.how big a difference is there likely to be between these two turntables when it comes to pure objective audio performance?
There's very little if any discussion on the new arm and its characteristics. It's clearly been engineered this time around to be cheaper in my opinion.
My informal tests of the A-T LP120 suggested something interesting: Although the A-T's platter has less mass than the SL1200's, and seems to ring equally well when struck, the very act of putting a record on the bare platter eliminated most ringing (I do not recall hearing any pure tones being picked up by the stylus), and the stock felt DJ mat alone was surprisingly effective at dampening platter vibrations.If you look at the link in post no.10, you'll see the plot given by Technics that compares platter resonant decay characteristics of different generations of decks. A classic problem with the MK2/3/4/5 is platter ringing, particularly when DJs remove the mat that it was designed to use and fit fabric mats that are 1/10th of the rubber mat's weight. This is easy to see: remove the mat and give the platter a rap with your knuckles.
If it were a real problem, it would be super-easy to spot at the output.What about cogging?
I guess it held up to DJ abuse.
But the 1200 arm definitely doesn't have any added DJ robustness over hifi arms.
It absolutely does. The gimbal with vertical bearings (lower ball races and upper needle) adds protection for the arm from vertical impacts and transfers any impact on the bearing housing direct to the plinth. Normal 'hifi' arms at a disadvantage there because the lack of the gimbal bearing places way more potential forces on the horizontal arm bearings when aggressively moved.
Sure, I agree the arm was built to a price, but it's a good overall arm. The part I don't like is the plastic central bearing housing and arm lifter pad- that should have been alloy from day one.
The Technics website states (with respect to the GR and I'm sure the other current models as well) "a newly developed coreless direct-drive motor and precise motor control technology that eliminates cogging from rotation irregularity."What about cogging?
Not following what you mean as all four bearings are the same.The gimbal with vertical bearings (lower ball races and upper needle)
You know what I'm talking about.Not following what you mean as all four bearings are the same.
This question was not entirely serious, because if there is any cogging, which can be imagined, it is so slight that I have not heard it even with a good system. I have owned several DD's, not only from Technics, from the time of their emergence until today.What about cogging?
