watchnerd
I'm rather liking driving my headphone amp straight from the pre-outs on my integrated amp (which has a built-in DAC), with no separate DAC and wondering how many others are doing that same.
I don't get the question. Why would one add a superfluous DAC if you have clean preouts and an analog headphone amp?
Because they want to spend money.I don't get the question. Why would one add a superfluous DAC if you have clean preouts and an analog headphone amp?
The headphone jack of an integrated amp or preamp is often a poorly engineered afterthought having high output impedance, limited power or non-flat frequency response. So I can understand using a dedicated headphone amp.
But I don't understand a separate DAC? How does that even work -- 2 separate digital outputs from the audio source, one for speaker system, one for the headphone system?
What's the output impedance?FWIW, my amp doesn't even have a headphone jack. The advice from the maker is to connect the headphones directly (sans amp) to the RCA outs.
I have a custom RCA->TRS cable and it actually works pretty well for low impedance / high sensitivity cans.
But things like HE6SE, no way.
XLR out from the streamer/DAC .. in my case Cambridge CXN V2 into Singxer SA-1I've seen that.
Example:
Streamer optical out into AVR, streamer USB out into standalone DAC
Which do you use for the volume control? Integrated with head amp at a fixed level?I'm rather liking driving my headphone amp straight from the pre-outs on my integrated amp (which has a built-in DAC), with no separate DAC and wondering how many others are doing that same.
It's convenient. Less weight, less clutter, less hassle. Can be connected to a number of sources alternatively, so you don't have to buy separate stacks for separate sources. For example one dongle is more financially and logistically efficient than two internal soundcards in two computers that you don't use simultaneously for listening to anything (e.g. desktop computer in your office and laptop for working in the garden or park). And given the progress made in miniaturization by this stage, the chips can be made small and you can fit plenty of them in a single box, though you'd better also be able to plug the whole thing into the wall for juice.I get having a separate headphones rig; but I prefer a DAC/amp combo device. Headphone amps are smaller and I can move them to different parts of the house depending on what I'm doing.
