New wireless headphones
There is a 10.band option in the preset menu. If you haven't bought the peq upgrade, the inbuilt geq isn't enough.
I have just found the settings.
Now I have 10 bands.
Thank you.
Hi you,
I a few questions regarding EQ + USB Audio Player Pro:
  • Is Output level and Pre amp gain the same? USB Audio Player Pro does not have Pre amp gain.
  • USB Audio Player Pro does not have filter "peak". What to use instead?
Thanks
All of Tonebooster's Bell filters are peak filters.
I am not sure what you mean.
Please look at attached picture from the EQ.
I am not totally sure if "Preamp gain" at the Oratory1900 is the same as "output level" in USB Audio Player Pro.
Any one?
Thank you.
Are you sure?
Why not use "digital bell" or "analog bell?
You're worrying far too much. Test, see which works best. Or go with what you've been advised.
Any one?
Thank you.
It is
Any one?
Thank you.
You can use the helpful "Auto gain" feature in the preset menu too- that will adjust the reduction to the right amount for any peaks in current playback to prevent digital clipping. So you can set the reduction just under the amount stated in the EQ file and know it will deal with any really high output content.
Thanks.
Great input, thanks.
I had the XM3 and auctioned the XM5 and Bose Ultra as an upgrade. The XM5 outclassed the Bose in all areas.
Given the similarities between the XM3 & XM4, I would definitely give the XM5 an audition.
Xm5 is the worst audio Gear I bought since my first cd stereo system.
I bought the xm5 around 500€ here.
The sound is clear for sure but the mids are awful for my ears. Treble and bass fatiguing.
I do prefer my old JBL HD elite.
Just wanted to know what OP settled for. I'm in the market for a wireless audio solution and because I keep breaking audio jacks (and plugs to a lesser extent), I'm looking at having at one pair of BT headphones, at least for backup if my bluetooth/usb-c DAC and amp option doesn't materialise.
