Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Thanks for all the responses, guys. I am still saving up for an STR-AZ7000ES, but was hoping since Sony is understandably not using Audyssey that they would have at least licenced Dolby Volume or added their own home brew equivalent to their 360 Spatial Sound Mapping.
It all depends on your listening level and content. Dolby Volume is pretty sophisticated for those who need it. Like many things, I am a big fan of user controlled features.
Dolby Volume did make your Arcam more expensive since it is licensed tech but at least for Sony’s loudness algorithm, it was in-house and surprising that it seemingly was removed.
My old Onkyo TX-NR5010 had both Audyssey Dynamic Volume and Dolby Volume. They each had their quirks but I liked them. I felt DV was less aggressive (in all it's equivalent settings) and even let the bass cut loose a bit more. However, unlike ADV, DV would boost all Dolby tracks by around +10 dB relative to other audio tracks. That was actually counterproductive. If they ditched that "feature", I'd have preferred Dolby Volume over Audyssey Dynamic Volume.
With the Sony there is a feature which is similar to Dolby Volume which is not only for Dolby. I believe it will work for all audio. I have to look it up but I believe it is like a loudness feature for audio at low volumes. It doesn't over extend the frequency range and immersion.
How does the STR-AN1000 with Digital Cinema Auto Calibration IX, $600 on sale, compare to the Onkyo TX-NR7100 with Dirac Live, at $650 on sale, or anything else in the price range? I am looking to replace a TX-NR656 mostly to get better room correction and secondarily to get the latest HDMI. I've also been eyeing a HDMI SACD player like the Sony UBP-X800M2 since I already have a bunch of SACDs but only analog outs on my current player. Speakers are the Pioneer Andrew Jones in 5.1.2. Apartment with lofted ceiling. Usage is primarily gaming, then movies, then music
edit: I'll have to check my library but a lack of HDR10+ may mean a pass
Are you referring to the Sound Optimizer featured in the ZA line, that GXAlan mentioned? Because it's not mentioned in help guide for the STR-AZ7000ES.
About two months ago my STR-AZ5000ES started a loud hiss when 360SSM was engaged. It was very annoying and after a couple of calls with Sony support, a full reset solved the issue and it’s now working fine.
Well the answer is debatable. Technically going to the Settings menu, the last option is the reset menu. Selecting all options should bring the unit to factory defaults. Amazingly my STR-AZ5000ES did not reset to factory defaults. It did remove the hiss when using 360SSM.
Since my last post, my receiver (STR-AZ5000ES) did the famous super loud pop then shut off and would not restart. It was shipped to United Radio who is Sony’s repair center. They found a blown fuse, repaired the unit and returned it in a total of 8 days from the date I shipped it.
Receiver is working fine, Only once had to power off and restart as my TV failed to display the HDMI signal via the eARC connection from the receiver.
My concern is the repair center did not comment what could have caused the fuse to blow!
If it hits 120x7, that means it will pull 840 watt from the wall socket and doesn't make sense for them to put 540watt on the back for max power usage.
You will never pull maximum watts from all channels simultaneously. Surround speakers rarely, if ever, demand significant watts. You can always use a 3 channel amp for fronts.
The AVR850 I would say slight edges out the Sony here. I find with listening to vinyl, I like the AVR850 a bit more. Certain frequencies stood out more over the Sony but not dramatically. The AVR850 sounded a bit more open but again so very slight. I compared both using the Direct Pure setting and with some processing as well, both stereo and multi-channel. I play around with both processing when listening to music. I find I love to use multi-channel for digital streaming being the music is everywhere in my home being it is so open. Reference songs were School and Bloody Well Right from Supertramp's Crime of the Century played on a Technics 1200GR with a Audio Technica 740ML cartridge > Whest Two.2 dual mono phono pre.
As per digital streaming and CD I would put them even. If the Arcam wasn't showing intermittent failure issues per the surround channels L&R, I would keep it. I find I can't be sending this back for another repair and paying for it being out of warranty. Consensus is the Sony stays and the Arcam will be sold if possible for a fair price. If I find no one is willing to pay a fair price I will keep it and use it elsewhere in my home.
I would consider bluetooth or Wifi Headphones. I have a pair of Wireless or wired Sony WH-X1000 M3 which I can use effortlessly with this AVR. In fact I prefer wireless then I can roam around gete a snack or drink and not miss anything. Wired Headphone jacks are going to be obsolete Sony just opt to move forward doing so saved cost on the unit skipping an outdated connection.
Better yet, connect headphone dac amp from monitor. Inexpensive and sounds much better than any avr headphone connection. Goodness, how many has Amir reviewed?
I've been saving up for a Sony STR-AZ7000ES. However, Amazon is offering a Denon AVR-X6700H for $1,895.00. That's very enticing. What would you recommend?
Or get it for $1,449 from Adorama! I’m having a very hard time not pulling the trgigger on this as it’s just not the right time for me, but man what price!
Yeah, I was shown that over at AVS Forum. I'm about ready to pull the trigger (even without qualifying for free shipping). I just never heard of Adorama before.
