New SMSL M500MKIII Hi Res Audio DAC & Headphone Amplifier ES9038PRO
SMSL-Mandy
Manufacturer
SMSL M500 MKIII Hi Res Audio DAC & Headphone Amplifier ES9038PRO OPA1612A MQA-CD DSD512 XU316 Bluetooth With Remote Control
Click for more: https://hifi-express.com/products/smsl-m500-mkiii
  • SMSL M500 MKIII using top performance D/A chip ES9038PRO from ESS Technology;
  • The high-performance power supply chip ES9311, the noise of ES9311 is as low as 1uVrms;
  • The 3rd ES9038PRO circuit design has a surprisingly low distortion of 0.00006% and is more stable;
  • The new PLFC headphone amplifier circuit enables the headphone to obtain more than 2W output power and less than 0.0001% distortion under 16 Ω load!
  • The new self-developed CK-03 clock processing circuit greatly reduces clock jitter;
  • XMOS XU-316, true 32bit audio processing, supports DoP and Native DSD, and reaches 32bit/768kHz and DSD512;
  • USB, optical, coaxial support DSD , coaxial and optical support DOP64;
  • Qualcomm's latest Bluetooth chip supports LDAC 24bit/96kHz, APTX/HD, SBC, AAC;
  • Specially designed discrete component linear regulated power supply and multiple low noise regulated power supplies to provide low noise power for analog circuits.
  • Use tempered glass display panel for higher light transmission and longer service life;
  • Built-in shielded, low noise power supply processing, while improving power efficiency,lower power consumption;
  • High quality gold-plated input and output jacks;
  • 9 high-end dual op-amps OPA1612 and a lot of audio grade components are used;
  • 1.9 inch TFT LCD display;
  • JAS Hi-Res certification;
  • Equipped with remote control and full-function remote control.
Specifications
  • Input ........................................................ USB / Optical / Coaxial / Bluetooth
  • Output .................6.35 Headphone jack /4 .4mm Headphone Jack / RCA / XLR
  • Line output amplitude..............................................................XLR 4.1Vrms
  • RCA 2Vrms
  • THD+N ....................................................... 0.00006%(-123.5dB)(UN-WTD)
  • HPA THD+N .....................................................0.0001%(-120dB)(UN-WTD)
  • HPA power ...............................................................2Wx2(16Ω),1Wx2(32Ω)
  • HPA gain ......................................................................0dB(Low),+9dB(High)
  • Dynamic range ........................................................133dB(XLR),126dB(RCA)
  • SNR .........................................................................133dB(XLR),126dB(RCA)
  • USB Spec................................................................USB 2.0 Asynchronization
  • USB compatibility ........................Windows 7 / 8 / 8.1 / 10/11(Needs Driver)
  • Mac OSX10.6 or Later、 Linux(Driverless)
    MQA decoder ............................................................ USB / Optical / Coaxial
    MQA-CD decoder ............................................................... Optical / Coaxial
    DoP decoder ............................................................. USB / Optical / Coaxial
    Sampling rate & Bit Width:
    USB PCM 44.1 ~ 768kHz(32bit)
    DSD 2.8224 ~ 22.5792MHz(1bit)
    Optical / Coaxial 44.1 ~ 192kHz(24bit)
    DoP DoP256(USB),DoP64(Optical / Coaxial)
  • MQA decoder ............................................................ USB / Optical / Coaxial
  • MQA-CD decoder ............................................................... Optical / Coaxial
  • DoP decoder ............................................................. USB / Optical / Coaxial
  • Sampling rate & Bit Width:
  • USB PCM 44.1 ~ 768kHz(32bit)
  • DSD 2.8224 ~ 22.5792MHz(1bit)
  • Optical / Coaxial 44.1 ~ 192kHz(24bit)
  • DoP DoP256(USB),DoP64(Optical / Coaxial)
  • Bluetooth: 5.0
  • LDAC ............................................. 24bit/96kHz (990kbps/660kbps/330kbps)
  • aptX-HD ......................................................................24bit/48 kHz_576kbps
  • aptX ..........................................................................16bit/44.1 kHz_352kbps
  • SBC ..........................................................................16bit/44.1 kHz_328kbps
  • AAC .........................................................................16bit/44.1 kHz_320kbps
  • Power Consumption ..................................................................................5W
  • Standby power ................................................................................... <0.5W
  • Size .........................................................................85x88x197mm (WxHxD)
    Weight
  • Weight ......................................................................................0.90kg/1.98lb
