New SMSL A300 BTL Class-d Power Amp
Kitarist
Does the NW1194 volume controller still work in logarithmic way? So basicly when its at half (30) it gives around 10% output?
iu
On the A20a-2019 it is linear. On the SMSL AS300 it is linear. I do not own the SMSL A300, but strongly assume it is the same, since all these amps use the same controller and go from -0db to 60db.
Kitarist
Hmm but i get around 85db when i'm on 30 35 volume on A300 with 85db sensitivity speakers.
Kitarist
Basicly just did measurements again with db meter i get like 75db on 40 volume. So in theory its not even outputting 1 watt at 40 volume ? Is possible my drivers are so hard to drive? I have Fullrange Markaudio Pluvia 7HD
Are you using the internal DAC of the A300? If so try putting an external DAC to it to see if it's the DAC causing lower volume/gain than expected.
Kitarist
Yes i'm using the internal DAC, also tried bluetooth and line in both same thing :) Also i think the volume on amp works as LOG when you increase it.
Toku
Japan
The A300's USB input is a simple bonus function that uses the DAC function of the BT module. This is the same method as AO200.
The USB input sampling rate is fixed at 48kHz 16bit, and the input level is about 6dB lower than RCA.
Kitarist
So the bluetooth also is 6db lower than RCA?
Toku
Japan
BT and RCA levels are the same.
I think that the reason why the level does not match with USB is that the level cannot be easily adjusted because the DAC function of the BT module is used.
TonyJZX
Just to clarify... 85w is basically at untenable THD? Like 5-10%?
At realistic THD say... 0.05% is power still at say 75w? less?
keenerz
for those using the master-slave mode how do you balance these things. I just setup two of them in BTL mode just trying to balance them out is little tricky, I have the right one set like 6(db?) higher than the left one.
edit: gonna experiment with two separate "left" channels
Toku
Japan
Please read my report on page 3. I've posted a few about BTL connections.
nsfgp
Yes please try both Master-Slave method(Using BTL-R loop back RCA R-ch out to slave) and direct-BTL (L-ch only on both) mode.
6 steps on the volume is significant.
In your Master-Slave setup => have you tried swapping the 2 unit (old master becomes new slave while keeping all source settings the same) and does the R-ch becomes the louder channel??
