Both are great speakers, the BMR Towers go a bit lower but with most music it isn't an issue. If you look at the distortion plots and the directivity combined with the other measurements, I'd take the BMR personally, but again neither is a bad choice.How do they compare with the ELX?
Josh,For those, like myself who are curious but not willing to read ~300 posts, can we put a link to the measurements in the first post? Just a suggestion.
I don't know. I have the BMR Towers (original), the Revel F328Be Towers, the Revel F228Be and the Ascend Sierra Tower with RAAL Tweeter. My order of favorite overall speaker is:
4. Ascend Sierra Tower with RAAL Tweeter
I purchased these speakers in late 2020 for about $3200 new. They sound nice with a subwoofer but without a subwoofer they are bit hollow when directly compared to the three models above. The first three speakers in this list sound fabulous without a subwoofer. I really like Towers that have excellent bass reproduction. I enjoy listening to full range speaker where matching a sub is unnecessary for normal music listening. I contacted Ascend to see about updating them to the ELX model. But found they wanted several thousand for parts. I verified my speakers were ugradable but you need to be prepared to take everything out and start over again. Drivers, crossovers, padding, etc... The other problem is the Sierra Tower case volume is a good deal smaller than the F228Be. I decided I would rather spend that money on the Revel F228Be than the smaller bamboo case frame. The Ascend sounds fine. It's just once I heard the F228Be against the Ascend - I completely lost interest.
Those are the links I was looking for.Josh,
Both Philharmonic Audio and Ascend publish measurements on their websites. Ascend has a Klippel and will provide measurements of the loudspeaker you purchase if you want to pay a few extra bucks.
philharmonicaudio.com
How did you end up knowing the cab are undersized? You got the thiele/small pareneter measurements? Unlike the revel, the drivers in the ascend elx are made in serbia and norwayHere's the thing. All the Sierra Towers use the same undersized boxey cabinet design with a flat board screwed to the bottom as a stand. It's a simple, basic design. Each cabinet is rear ported full of 160gram of acoustic stuffing. The only variation is drivers and crossover. Ascend charges buyers upgrade fees for new parts to fit the same unimaginative cabinet while issuing a letter with each version claiming it's one of the most advanced audio designs ever. It's kind of a funny design/marketing concept.![]()
If someone wants to offer me another new pair of Walnut Revel F228Be in exchange for my Sierra Towers with RAAL Tweeters I would happily accept.
After living with RAAL Tweeters in the Sierra Towers versus Revels Be Tweeter for several years, I much prefer the smoother sound of the Be tweeter. To my ears, cymbals, snare and hi-hat all sound more realistic. While the RAAL is a high quality driver it can have an edge to it that sounds a bit artificial. In addition, the Revel Be Tweeter dispersion is 10x better. You can stand as well as sit with the Revel Be and not hear the highs change dramatically. With the RAAL you need to have ears located at Tweeter height. If you get up, you immediately notice the difference. It's a much more directional design. While the Sierra Towers can offer a nice mid-range punch, they don't offer the fullness of sound and absolute power of the Revel F228Be. It's an entirely different class.
It's also hard to spend $2200, do all the work of installing new drivers/crossovers and soldering and not know what Frankenstein monster you will end up with. I much prefer buying a known sound that I have already auditioned and not depend on my DIY soldering skills and assembly. I would hope a skilled professionals with experience can offer a superior install. They would have tools to test and troubleshoot the final result. You could have defective parts or poorly soldered connections and not even know it. Professional design and assembly within tolerance are valuable.
It depends how you like to enjoy and listen to music? Personally, I prefer a speaker that sounds great when I'm standing or moving about the room.
If you like to do any of the following I wouldn't recommend the RAAL Tweeter:
1. Exercise with music
2. Play pool
3. Dance
4. Have guests over who mingle while standing
5. Play along with instruments while standing with your stereo
6. Any activity that doesn't keep you seated in the RAAL sweet spot
Having a speaker that sounds great standing or seated is so much more flexible than one with a RAAL Tweeter that demands the listener be seated for a decent sound.
FWIW I have both RAAL common tweeters, 60 and 70, and the Satori BE and I go back and forth on my preference. All 3 are Dennis Murphy designs with the BMRs standmounts only having one tweeter component. They all sound great to me and I wouldn't easily have a favorite.It depends how you like to enjoy and listen to music? Personally, I prefer a speaker that sounds great when I'm standing or moving about the room.
2. Play pool
3. Dance
Placement, tweeter diffraction treatments, or DSP are options that easily deal with first reflections. I don't have any issues as placement solves most issues for me. Dennis has, a long with Paul Kittinger, designed many great speakers that have been easy for me to deal with in room. YMMVIMO you really have to treat the sidewall first reflection points with RAAL/BMR speakers. Looking at dispersion plots, you're getting 3-6 dB more upper frequency (>2 kHz) sound coming from sidewall early reflections from a RAAL/BMR than something like a Revel tweeter with a waveguide. The impact on clarity and imaging is very obvious, one can put up/take down sidewall panels and it's very obvious how much sidewall reflections degrade the sound quality.
You have the concepts down of what I was referring to and DSP can reduce the intensity. My rooms are unique to me so it varies. My Be tweeters are in a very large room but the distance to the side walls is fairly similar to my other setups and I don't have first reflection issues. I should measure them to see what actual affects are occuring, I just haven't felt a need as the sound is good.Please explain more how these would work.
Placement: sure you can change toe-in/toe-out to change how the sidewalls interact, but you're still getting sidewall interaction, either the left or right wall
Tweeter diffraction treatments: you mean like blinders? Doesn't seem like a good idea. Waveguide would help, which Revel implements.
DSP: how? DSP doesn't change dispersion width. Maybe some exotic active cancellation could do it...
Only "easy" way to deal with early reflections, AFAIK, is to (1) put up absorption panels or (2) just remove the wall entirely and go free field (or have the wall so far away that the arrival time is well after direct sound, so your perception doesn't combine them as one, which smears the sound).
Wow - congratulations!Greetings from a new customer in Finland. The first Philharmonic Audio Speaker Family picture:
We are so inspired that we should prepare Philharmonic Audio speaker family picture.![]()
