New measurements for Beyerdynamic 700 and 900 Pro X
Yuhasz01
Any where to read measurements for new Beyerdynamic 700 and 900 Pro X headphones?
_thelaughingman
I don’t think you’ll see any reviews or measurements yet since these are new products.
usern
@Merkurio found measurements posted on reddit: https://www.audiosciencereview.com/...ro-review-headphone.19975/page-29#post-938182
_thelaughingman
Y
Yuhasz01
it's caused by the measurement apparatus, so I wouldn't fully trust that measurement result in that region.
Somebody send me a pair and I'll measure them :)
Solderdude addresses this issue for dt 770 .
mslim
Google is your friend
Got measurements but using a different system. Close enough. Doesn't look good. Their Tygr 300R was closest to Harman's curve and was well "liked" - guess they are not targeting this.
I do like their new design and build. I don't like throwaway design culture and like their repair culture.
Y
Yuhasz01
Site graphs unhelpful, and no idea what measurement system used.
mslim
The general impression of the frequency-response curve is not "Harman". Can't wait for Amir's test.
Noodles
Netherlands
I had the 900 for a week - sounds well enough ... sort of small though. It's like listening to 2 very well measuring but small speakers ... it's super weird.
They also changed the pads system - the retention ring is now glued to the pad and you can't use all your other beyer pads on these two.
testek
i hate glued pads, wish they kept the old swapping system.
M00ndancer
Sweden
More revenue for the manufacturer. Harder for third party to copy the design.
Noodles
Netherlands
They are interchangeable - the retention ring is not glued to the frame - but if you have owned a beyer before, you will know how crappy this new system is.
In any case - if you would have to choose between these two - 900 pro x all the way.
M00ndancer
Sweden
Can't, only closed cans are allowed in my household. WAF...
But the 700 seems to be okay. I'll ordered them and they will arrive on Wednesday.
