Hi,
I would like to mount my kh310 on a wall.
I know that Neumann sell accessories for that but they are very expensive.
My idea is to use a tv wall support and to attach it to the kh310 vertical existing brackets on the kh310 back side with an adapter that I would build.
But I am a bit worried that these brackets on the back side of the kh310 can not be used for this and that could damage the kh310 structure.
I have contacted Neumann support and they replied that I can use the kh310 rear side brackets to mount them on a wall but after that they told me that I would be able to find the explications in the kh310 installation guide. The problem is that there isn't anything about that in this guide and so I suspect that they did not understood what I meant!
Any idea ?
I have also thought to use a wall support with a plate to put the kh310 on the plate but it very hard to find.
Thanks!
Any idea ?
Thanks!
