Jose Hidalgo
Hi everybody,
I'm currently designing my future PC desk setup, and besides performance, I'd like it to be as clean as possible visually. For example, the large 45" 21:9 curved monitor (3440x1440) will be wall-mounted, so no visible foot/feet, and no visible cables either: it will just 'float' over the desk.
I'd like to do a similar thing ('invisible' wall-mounting) for the speaker system.
Ideally I'd like speakers that can be wall-mounted from behind, in order for the stands/supports to be as invisible as possible. I know there are stands/supports designed for speakers to just lie on them, but I think they're a bit too visible, so I would only use them if there wasn't a better solution. In other words, while performance matters a lot, aesthetics matter too.
Main use will be music listening (I listen to a lot of music when I'm at my desk). Secondary use will be light gaming.
So naturally I would lean towards a couple of near-field active monitors.
However, I'd also welcome a subwoofer, because a couple of relatively small speakers can only go so low in frequency.
So in the end I think a 2.1 system would probably be best for me.
The subwoofer can either be included with the system, or bought separately.
Taking all that into account, what would be your recommendations for a max budget of about 1K€/$?
Please let me know if you have any questions.
Thank you.
Thank you.
