Neumann KH 750 DSP + KH 310 A review
@pozz @DjBonoBobo what I regret is that I would have to buy a sound card that I would never use anymore
You will use/calibrate probably several times not only once. After each change in room, reposition and so on. You can buy some cheap one with phantom and asio drivers.
could you kindly suggest me some model?
Thank you very much
P.S.: my pc is Macmini
I agree with @audafreak. Some Focusrite models have been reviewed on ASR.
Reviving an old thread.. I'm going double KH750 soon.. what's the way to go forward setting it up with the MA1?
Thinking in the 2nd sub to my setup .
Did you do it ?
What’s the setup easy ?
Are subs in stereo ?
If yes did u notice a major sound difference from 1 to 2 subs ?
310s + 1 750 sub here and pretty happy
I'm quite happy with 2 310 & 2 750 in stereo mode and aligned by ma1.
Really nice :)
As I’m doing mastering I’m thinking to add another 750 sub to have them stereo but trying to understand what do I win vs troubles with room , etc .
I work in a small space 4x3m well threatened acoustically.
In your experience did you have one , then added the 2nd ?
Did you notice room modes or much better listening experience when the 2nd was added ?
Thanks in advance
Really nice :)
Thanks in advance
Thanks. I have two from the beginning. According to what i heard, one 750 cannot match the output of a pair of 310. A pair of 750 is a good match for a pair of 310. Meanwhile, a 310 and a 750 for each channel seems a good arrangement.
Hmm yes that’s another positive factor however i don’t ear that pouch much often.
Many thanks for your response
Reactions: HQY
