Neumann KH 310A Review (Powered Monitor)
dfuller
So will two KH310 II's + two KH750's be the ultimate grail of audio glory? Seems like it :)
If the kh310 II is as much better from the 310 as the 120 to the 120 II then we're in for a good time.
My wishlist is as follows:
- lower cross (maybe 450-500hz instead of 650) for mid driver to woofer to move the one toothed comb flare to a less offensive area - possible with the really steep 8th order FIR xover filters they've been using.
- higher cross for tweeter (maybe 2.5-3khz) to let that mid dome do more since it's such a good driver
- take a page out of the kh150's book and give it that near-Purifi level of driver design.
FWIW, the kh750 is already a bit.. not enough, for a 310. It doesn't get particularly substantially louder. Better to match it with a sub like a Rythmik F12 or equivalent
Infinit0
And the M1 haha, don't forget :D
Bear in mind that probably that combo will cost something around
KH310II (5000) KH750x2 (3000)
We are talking about 8000 budget And that's is a pair of Genelecs 8351
Or a pair of 8341 + Sub
dfuller
Not for nothing, but the 310 is already approaching the 8351 in terms of SQ.
Reactions: Pio
SlothRock
If the kh310 II is as much better from the 301 as the 120 to the 120 II then we're in for a good time.
I can totally see one KH750 not being enough for the 310's but what about 2?
Filio45
Can the 310a's go pretty much up against the wall or do they prefer a little space from it? Just curious
Chr1
Using two current KH310s with a pair of BK XXLS400FF subs with MathAudio RoomEQ and rekon I would need to spend a lot more money to get better sound. Look forward to seeing how the new model compares for sure.
Not needing inbuilt DAC, DSP/EQ, so not sure if the inevitable price hike will be worth it. Better drivers, specs tho would. Depends on the price.
DJBonoBobo
any germ
Well, you have some wires that need to get plugged, so you will need at least a few inches of space from the wall.
Pio
Infinit0
Wait!! What??? Know for sure?
Yes. KH420 was released in 2015
Kh120 released in 2011
Kh310 released in 2013
Considering the new KH310 Will be released next year you could have a new KH420 in 3-4-5 years from nos
Also there is a picture in this forum and someone asked To neumann problem i cant find it
Reactions: Pio
Pearljam5000
Not Necessarily
They could make it a shorter cycle with KH420 II If they already developed the new tech for KH120 II and KH150
Takanaka
I hope the GKH 310 grill will still fit on the MK2 model. I don’t want to spend 400 euro’s again on frickin protection grills lol. :p
