I thought someone said the jitter issue was also fixed after the review.What mixed bag? The jitter "issue" is inaudible and the product was recommended.
The only feature missing that should be there is the unit acting as a USB DAC
Waaaaay beyond, Stereophile is monthly, Amir is daily! (give or take) And he goes much deeper than the magazines, which is why (for example) he found the issue with the OPPO that no one else did.Thanks Amir for this review. As a one-man operation, he seems to be measuring/reviewing gear at the rate of operations like Stereophile/Absolute Sound--or maybe even beyound. How this is possible I can't imagine.
I had my eye on this NAD component for a while ... moving on.
I own the C658. While it does sound good when streaming Tidal or local music from network. It has a ton of bugs. Subwoofer output is almost silent. Pops and clicks coming from the speakers and sub when no music playing. Audible hiss if you get closer to speakers. Very large latency on analog inputs (500ms). Mine is connected to NC400 monoblocks and Focal Aria 906 speakers. I wich I new better before buying it/
You simply cannot trust commercial reviews:
https://www.whathifi.com/reviews/nad-c-658
https://hometheaterhifi.com/reviews/amplifier/nad-c-658-bluos-streaming-dac-review/
https://www.soundstagesimplifi.com/...iews/107-nad-classic-c658-bluos-streaming-dac
https://www.stereonet.co.uk/reviews/nad-electronics-c-658-bluos-streaming-dac-review
I've seen 6 different reviews before buying and all of them praised it... go figure...
P.S. what seems to be the problem with the digital inputs exactly? Mine are functioning OK. The same goes for the HDMI module. If they cant sync, how are they functional and play music w/o a problem (except when the sample rate is changed between songs, then you get a pop sound)
Pops and clicks can indicate a clock sync issue, which is what the review revealed on the digital audio inputs. Do you get the pops and clicks when streaming over the network?Pops and clicks coming from the speakers and sub when no music playing.
It syncs enough to generate audio (i.e. recover audio samples). It is just that it is not stable, jumping back and forth on what rate it thinks the input is. So your music is constantly getting modulated by this.P.S. what seems to be the problem with the digital inputs exactly? Mine are functioning OK. The same goes for the HDMI module. If they cant sync, how are they functional and play music w/o a problem (except when the sample rate is changed between songs, then you get a pop sound)
Wow. If this is what all units are doing when they are hearing pops and clicks etc, that would be quite the defect. And if our past experience shows us anything... NAD will say:It syncs enough to generate audio (i.e. recover audio samples). It is just that it is not stable, jumping back and forth on what rate it thinks the input is. So your music is constantly getting modulated by this.
The only feature missing that should be there is the unit acting as a USB DAC. It has a USB connector but that is it acting as a host, playing content from external storage.
Rich, as far as the miniDSP SHD goes, knowing how you've shown a preference through the years for the higher end gear and considering the less than stellar measurements that Amir reported from the review of that unit, I would look more into the miniDSP SHD Studio version. That unit has no analog outputs and costs $300 less, so you can take that money and use it to buy any number of good and affordable DACs that should arguably yield better performance than the analog section of SHD. An issue to consider with both of these miniDSP SHD units is that they don't offer USB input if that's important to you.Thanks for the tip!
It looks interesting.
- Rich
Why aren't there any decent audio streamers with Dirac Live or other corrections? I refuse to buy a unit "blind" without a thorough measurement by @amirm. After finding this site, I only purchase equipment that's been tested here. I haven't been disappointed yet, every piece of gear works great. I mostly listen to several headphone setups, but It would be nice to be able to enjoy music through speakers once in a while.
I just installed a MiniDSP with Dirac Live, and it does really improve my speaker setup, which used to be abysmal, but now it's quite nice. I want a streaming pre-amplifier with Roon and Dirac Live support.
Here's hoping for a good and not too expensive unit shortly.
