Monoprice Liquid Spark DAC by Alex Cavalli Review
FrankF
North of New Haven
Good showing by the Alex Cavelli and the Liquid Spark. I have never owned his previous products but some people who did described it like this:
bobbooo
I use my LG V series phone for the vast majority of listening these days.
While I understand that this DAC is generally for laptops, phones without decent DAC's and other such connections, out of curiosity does anyone think that there would be audible differences between an LG phone with the "quad" DAC and this little unit?
No there won't. Not only that, there won't be any audible difference between this DAC and an average smartphone either e.g. the now three and a half year-old Samsung Galaxy S8 with a SINAD of 96dB (the ranking tables incorrectly show it as 89dB for some reason). The same goes for the S9, S10, Note8 and Note9 series which all use the same Qualcomm WCD9341 DAC, as do many other phones, or other similarly well-performing DACs.
This is because this level of distortion in a smartphone is already way below the distortion of a headphone transducer. In fact, even if you had the $60,000 Sennheiser HE1, the lowest distorting headphones in the world at 0.01% THD (which translates to -80dB), the combined distortion with a smartphone having THD at -96dB would be (worst case, in phase) -79.9dB i.e. an inaudible 0.1dB additional distortion. The DAC SINAD required for audible transparency with a typical headphone with (much) higher distortion would obviously be even lower.
mhardy6647
So -- it's taken me nearly a year to realize that I hate youse guyses.
I've been looking for an affordable DAC that would "do" DSD and not be embarrassing to purchase.
Here, it looks like we have one -- but the DAC chip that is at its heart was instantly rendered a collector's item by the (in all seriousness, terribly unfortunate) immolation of the manufacturer's plant. :(
Daggummit!
PeteL
No there won't. Not only that, there won't be any audible difference between this DAC and an average smartphone either e.g. the now three and a half year-old Samsung Galaxy S8 with a SINAD of 96dB (the ranking tables incorrectly show it as 89dB for some reason). The same goes for the S9, S10, Note8 and Note9 series which all use the same Qualcomm WCD9341 DAC, as do many other phones, or other similarly performing DACs.
The problem with phones is the output power, not the dac, but since as you point you can’t get better than the weekest link, the performance of the dac has not much significance.
bobbooo
Most smartphones will have enough output power to directly drive the vast majority of portable headphones to loud enough levels, and enough power to act as a DAC to feed a desktop amp to drive non-portable headphones to loud levels too.
@amirm your review showed up in my Google News feed
Thanks for letting me know. What is amazing is that I read Google News a dozen times a day and not once has it shown me any of my own reviews! It shows me audio reviews from others but not from ASR. Shows how dumb their algorithms are.
What is a "portable" headphone? And no, they are not good enough for vast majority of headphones. Try to listen to one on an airplane. Even at max volume you will have trouble getting sufficient volume.
PeteL
loud level is not synonim of sufficient power, depending on the impedance curve of the headphone, when you have like 5 or 10 miliWats, You may be have enough volume, but the bass response will suffer and you won’t get proper headroom for loud transient in dynamic recordings. As for using them as a line out, they have an output voltage below 1V, often considerably less, this is far from optimal when used this way.
raistlin65
Grand Rapids, MI
It's the Google News feature that shows up in Android Chrome Beta new tabs, which may be more personalized then the Google News app. Or maybe it functions completely differently. But it does recommend all kinds of news, much like the separate app.
gvl
SoCal
They know you wrote them and filter them out?
AudioSceptic
Northampton, UK
A "portable" headphone is one specifically designed to be used with a phone or other portable player, so efficiency is a necessary part of the design. You've seen all those people out and about using such, I'm sure. In my case, I use efficient and good sounding IEMs rather than over-ear headphones that to me just look silly outdoors. Headphones designed for use indoors with a proper amp are another matter.
Labjr
Google sucks. When I do a search for something, it returns more unrelated ads. It's becoming useless.
PierreV
It would be heck of an algorithm if it knows I wrote them!
I had plenty of ASR in my feed until I flagged them as "not interested" - the reason is obviously not that I wasn't interested but that I find it annoying when it suggests stuff I have already read. Likewise, I do prevent my usual news sources from showing up since I read them anyway.
It seems they prioritize engagement above anything else, at least for me. For example, I spent some time reading a suggestion yesterday (some stuff about bicycle maintenance) and came back to it a couple of times. This morning I woke up to no less than 12 bike test links.
DanTheMan
That is lousy. Hopefully there is enough stock in the hands of these manufacturers to keep lines in production until AKM can resume operations.
