Meridian inversion PEQ method - comments or caveats?
klettermann
Coastal Connecticut
In this thread @LDG_ recommends the EQ method described by Meridian Soundworks as described HERE. The write-up is very detailed and informative and involves various manipulations of REW measurements to create EQ filters for DSP. In a nutshell the process is:
  1. Take room measurements - single L and R measurements at MLP.
  2. Convert measurements to smoothed minimum phase copies
  3. Design the target curve and make a minimum-phase copy of that
  4. Generate inverted versions of MP measurements from step 2.
  5. Export the inverted curves as a stereo .wav file at desired sampling rate(s). These are filters.
  6. Export filters to convolver (MiniDSP Studio in my case)
Can anybody comment on this method? First, it just uses MLP speaker measurements, which would be a limitation for many I suppose. Is this somehow better than just using REW's EQ funtionality to generate filters? And what's the purpose of the minimum-phase conversion? Finally, it seems rather involved as opposed to automated methods like Dirac. Regardless, I guess I'll try it and see what happens. In the meantime, thanks in advance for any remarks or suggestions. Cheers,
@UliBru might want to comment and share some of his knowledge as well
If the correction is made only to the measurement converted to minimum phase (i.e. we are not correcting phase beyond minimum phase which PEQ's will automatically correct), what benefits are we getting over using PEQ's which are much more computationally economical? It is not like we need to correct every little wrinkles in the frequency response, and 10 PEQ's should be more than enough.
that's @OCA's area of expertise :D
The method described in that link is based directly on one of my older video tutorials. While I didn’t have the chance to read the entire post, I didn’t notice any reference. That said, it’s a solid approach, though the added complexity of generating a minimum-phase version of the target curve is unnecessary and best avoided.
I’ve also recently moved away from using direct inversion because the sharp edges of inverted filters can introduce minor phase and group delay issues—even in their minimum-phase versions. Instead, I recommend using REW’s minimum-phase auto EQ filters. These filters are much easier to implement in a MiniDSP and more practical overall. Exporting a convolution filter as described in the link isn’t suitable for MiniDSP due to its limited tap count; that approach works better with platforms like Roon or EQ APO, which can handle unlimited taps, as shown in my video.
In summary, working on the minimum-phase version of the speaker response is absolutely the correct approach since it represents the only truly correctable part of the steady-state response. However, sticking to REW’s EQ filters, applied to the bass frequencies of an "unsmoothed" min phase speaker response, will yield better results.
Hi @OCA , what is the "REW’s minimum-phase auto EQ filters"?
"However, sticking to REW’s EQ filters, applied to the bass frequencies of an "unsmoothed" min phase speaker response, will yield better results."
CMIIMW, the step that you mean is: measure speaker FR -> generate min. phase copy -> EQ in REW to the target curve -> and apply the filter in miniDSP or equalizerAPO?
Yes, untick "drop filters if small" default option in REW/Preferences while you are at it. But do not eq above 200-250Hz.
Reactions: Tio
If I'm not mistaken the majority of tutorials/guides/ASR doesn't mention working on minimum phase though, any idea why?
edit probably because you're talking about EQing speaker itself here, not room?
AFAIK, nobody used the technique before. It's actually based on a very basic and hard to argue with idea so it's interesting that it's undocumented.
Huh. What I get from this is that the inversion/minimum phase approach is solid yet best avoided. And then the min phase is the absolute best yet using REWs filters yields better results. I certainly don't understand it well enough to grasp these apparent contradictions but, the way it's stated, it seems pretty nonsensical. So, at the end of the day I guess I'll stick with REW and MSO EQing. Maybe Dirac too but so far just REW and MSO seems to sound best. Cheers,
Inversion on target and REW auto EQ on target are pretty much the same operations. And what I said to be avoided and unnecessary is about creating a min phase version of the "target curve" not the "speaker" response.
I remember seeing threads about various DRCs on ASR, but I couldn't find any threads based on REW.
Depending on the need, FDW, MTW, and Any Smooth(Such as Var, 1/3~1/48, Psychoacoustic...) can be adjusted, and below is the REW result based on Var Smooth, aligned with Mitch's SOTA DRC content.
pre-ringing cutoff for compensation filter has been fully applied.
The applied measurements are from some of my measurements from a few years ago.
FWIW, I like to keep it simple. I agree with @NTK that we don't need to correct every wrinkle. I use a simple manual process.
First, measure a sweeping from the listener position using REW. Now suppose it shows a +4 dB bump from 80 to 130 Hz. To compute the PEQ band to correct this:
Compute the ratio of 130 to 80: 130/80 = 1.625:1.
Take the square root of this: 1.274
Multiply by the low frequency: 80 * 1.274 = 102 Hz.
This (102 Hz) is the center frequency of your PEQ band, since 102 / 1.274 = 80 and 102 * 1.274 = 130.
Your PEQ is -4 dB @ 102 Hz.
Now to compute its width. You can express width by ratio, by octave or by Q.
The total width in ratio is 1.625:1, which is 1.274:1 on each side of the center.
If you want that in octaves, log base 2 of 1.625 is 0.7, so it's 0.7 octaves wide (total).
Note that this passes a sanity check, since 1 octave is a frequency ratio of 2:1 and 130 is not quite twice 80.
Now you can compute Q (formula), and Q= 2.04.
There's your PEQ to correct this bump. Repeat the above process for each bump you want to correct.
